NEW Merkur part of the week
- merkurdriver
Re: NEW Merkur part of the week
NEW NOS XR4Ti Coolant Hose Lot:
https://www.ebay.com/itm/202518982762
NEW NOS XR4Ti / 2.3T Ford Turbo Coolant Line Hose:
https://www.ebay.com/itm/192741571002
XR4Ti Blue LED Converted Digital Clock:
https://www.ebay.com/itm/Blue-LED-Conve ... 2739107628
NEW NOS Ford Sierra Cosworth 108mm Rear Outer Stub Shaft:
https://www.ebay.com/itm/NEW-NOS-Genuin ... 2731615681
okay, will do.
- merkurdriver
NEW Cosworth (clear) Front Turn Signal Lenses:
https://www.ebay.com/itm/192265849468
NEW Cosworth (stock amber color) Front Turn Signal Lenses:
https://www.ebay.com/itm/202570391341
Slowly updating the website...
This page has been completed with new parts added and lower prices:
http://www.merkur.50megs.com/catalog_2.html
clear for the xr would be nice.
- merkurdriver
NEW NOS Merkur XR4Ti Leather Headrests:
https://www.ebay.com/itm/NEW-NOS-Merkur ... 2824974497
NEW Cosworth / RS500 Bumper Clear Front Turn Signal lenses:
https://www.ebay.com/itm/NEW-Ford-Sierr ... 2816583795
NEW XR4Ti Front Control Arm Set:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 2363263034
- merkurdriver
NOS Merkur XR4Ti Grey Front Leather Seat Cover Upholstery:
https://www.ebay.com/itm/NEW-NOS-Merkur ... 2831224003
Prototype 1989-specific XR4Ti Aluminum Coolant Tank:
https://www.ebay.com/itm/192832525727
NEW Right Side Cosworth Front Bumper Turn Signal Lense:
https://www.ebay.com/itm/NEW-Ford-Sierr ... 2600798750
- merkurdriver
Our XR silicone lower radiator hoses are back in stock with improved construction of 4 ply vs. 3 ply on the previous version. Matte black and blue are currently in stock at www.merkurdepot.com and the blue ones have been added our ebay store at:
https://www.ebay.com/itm/192866280975
The topmost 1985-1988 XR coolant expansion tank hose has also been added in blue:
https://www.ebay.com/itm/202632271365
- merkurdriver
NOS XR4Ti Fuel Level Sending Unit:
https://www.ebay.com/itm/202637766285
NEW Cosworth Glass Headlights for the XR4Ti:
https://www.ebay.com/itm/192872685938
- merkurdriver
NEW NOS Ford "late-style" 1987-1989 Merkur XR4Ti Brake Master Cylinder with Reservoir:
https://www.ebay.com/itm/NEW-NOS-Ford-1 ... 2885227624
(Used) Cosworth Grille:
https://www.ebay.com/itm/202650397691
- merkurdriver
All metal, direct replacement for the stock heater core now available at www.merkurdepot.com -> NEW PARTS XR4Ti ( and NEW PARTS SCORPIO).
Stock replacement (plastic tank) heater cores have now been discounted on those same pages as well.
The all metal units are also available in our ebay store:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 2916321253
- merkurdriver
NEW Scorpio Inner Tie Rods:
https://www.ebay.com/itm/NEW-1988-1989- ... 2729991957
(used) XR4Ti / 2.3 Turbo Ford PM Motorsports Plenum Intake Manifold & Fuel Rail:
https://www.ebay.com/itm/Ford-2-3-Turbo ... 2728436122
(used) 70mm BBK Throttle body for use with Intake manifold above:
https://www.ebay.com/itm/BBK-70mm-Throt ... 2725348148
(used) Mustang SVO "PE" ECU Engine Computer:
https://www.ebay.com/itm/Ford-Mustang-S ... 2968963563
crossed drilled
- merkurdriver
Drop me a line directly at merkurdriver@gmail.com for the rotors you need
done sir
- merkurdriver
NEW NOS XR4Ti Front Plate Bracket Kit:
https://www.ebay.com/itm/202785667595
NEW NOS XR4Ti & Scorpio Driveshaft Bearing:
https://www.ebay.com/itm/NEW-NOS-161302 ... 2769259893
NEW XR4Ti & Scorpio Lug Nuts for Factory Wheels:
https://www.ebay.com/itm/NEW-Ford-Merku ... 2987324179
NEW NOS Genuine Ford Fuel Pump + Sending Unit:
https://www.ebay.com/itm/NEW-NOS-Genuin ... 3073940945
NEW Merkur XR4Ti Silicone Coolant Hose Oil Cooler to Metal Pipe:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 3058871419
