Eaton LSD
reddy2300
Re: Eaton LSD
Post by reddy2300 » Fri Jun 14, 2019 1:28 pm
Dumb question: Will anyone please share the part number for the correct diff for our application? For posterity?
911A319?
Re: Eaton LSD
Post by hEaT » Wed Aug 07, 2019 1:15 pm
911A319?
That's the TrueTrac I think. Do you want that or the clutch type LSD?
Joe
1985 Nimbus Grey XR
2017 Ford Focus RS
reddy2300
Re: Eaton LSD
Post by reddy2300 » Thu Aug 08, 2019 10:22 am
Well, it's funny that you would ask that question. I did want the TrueTrac. When I ordered, Chris thought I wanted the clutch type so that's what he sent. Being that I was on the fence about which one to get, I decided to keep the clutch type. We'll see how that works for me. If I don't like it, I can always sell it and get the TrueTrac to put in one of the other diff cases I have sitting around
Re: Eaton LSD
Post by hEaT » Mon Aug 12, 2019 10:25 am
FWIW, I've only raced once or twice with the Eaton. The rest of the miles have been on the street and I have zero complaints with the Eaton. It's quieter than my OEM diff was in all scenarios except coming to a stop in neutral (get some "whirring" from the rear). I am on solid beam and diff mount though.
Joe
1985 Nimbus Grey XR
2017 Ford Focus RS
Re: Eaton LSD
Post by my8950 » Sun Sep 08, 2019 6:22 pm
Mostly Eaton in here, but I'm wondering if anyone has a model year for the T/A Camaro or Firebird rear diff that fits. I know 82-93 or so, just wondering if I might be able to find one in a yard or part out. I have a few diff housings from the XR, might attempt to do the swap on the cheap to see if I can get it to work.
Thanks!
reddy2300
Re: Eaton LSD
Post by reddy2300 » Fri Sep 13, 2019 5:00 pm
Here's the description from the Jeg's website. Says 10-bolt from '75-'89.
https://www.jegs.com/i/Detroit-TrueTrac ... 9/10002/-1
