2.0L Ford Racing EcoBoost swap into an '87 XR
xrpl
Re: 2.0L Ford Racing EcoBoost swap into an '87 XR
Post by xrpl » Thu May 07, 2015 4:58 pm
Here are the engine mounting points:
Post by thesameguy » Fri May 08, 2015 2:50 pm
ZOMG... mind if I asked what the mill & controls set you back?
Post by DPDISXR4Ti » Mon Apr 03, 2017 7:35 am
Any update on this project?
timxr8
Post by timxr8 » Mon Jul 24, 2017 9:47 am
xrpl wrote:...Any suggestions out there for a new in tank fuel pump? The Ecoboost does not need the in line pump as it has a high pressure pump on top of the engine.
WHOA, totally missed this...You have to use a FI pump to feed the HPFP!!!! The pump on the engine takes the ~50+psi and boost to over 1000psi for the DI. The in-tank pump will not properly feed the DI pump at low pressure. It must use FI level of pressure to feed properly.
Also, any update? I know I have no room to talk with my Dtec build, but always enjoy prodding others.
cmouta
Post by cmouta » Fri Aug 18, 2017 2:44 pm
I'm sure this guy David Clark is a member on here, no? Surely he's got plenty of details
https://www.autocar.co.uk/opinion/motor ... car-podium
Post by DPDISXR4Ti » Wed Sep 18, 2019 8:05 am
What ever happened with this project?
taylor0987
Post by taylor0987 » Wed Sep 18, 2019 9:52 am
This seems to be the car, as the photos in one of the videos are the same as those in this thread. https://www.youtube.com/channel/UCCAEk8 ... kwNoE1SSTQ
