FallenOne121's Project Build
fallenone121
Re: FallenOne121's Project Build
Post by fallenone121 »
The Journey was SHOCKing
Have heard people are interested in the setup of suspension I did for springs and all...so figured I would post here as well:
Bilstein B6 Front (PN: 35-040408)
Eibach Front Coilover 250 lb (Ground Control 4105 - Also I advise to order Helper Springs from them and verify they are sending the 47.7 split sleeve to fit Bilstein shocks)
Bilstein B6 Rear (PN: 24-018067)
Eibach 9.5" x 5.5" 500 lb Rear Springs (PN: 0950.550.500)
The spring rates were verified via Greyson and Jeff Herson as viable daily street setups.
The reason I went for B6 vs B8 is because the B6 isnt a 'lowering' shock - I didnt want to lose any clearance. The B8 are by their nature a shorter shock.
Charles McMillan
Battle Creek, MI
fallenone121 wrote: Tue Apr 02, 2024 10:36 am
Eibach Front Coilover 250 lb (Ground Control - Also I advise to order Helper Springs from them and verify they are sending the 47.7 split sleeve to fit
Part number on the springs?
fallenone121
my8950 wrote: Tue Apr 02, 2024 1:05 pm
For the Ground control front you get to choose what spring rate you want on the order (Part 4105 on their site)
Rear would be 0950.550.0500
Charles McMillan
Battle Creek, MI
fallenone121 wrote: Tue Apr 02, 2024 3:58 pm
Thanks!
