Anyway, removed seats, removed rest of the interior trim, removed some misc fittings and have the dash ready to be pulled after taping off areas to cut. Cut out old harness bar. Plan on making some progress this weekend. (saturday) Sunday is a Whisky Festival.
3 23' long sections of 1.75" x 0.095" DOM tubing. The white tube is my old harness bar.
In the background is the TIG welder, tubing bender, tubing notcher, drill press, etc.
More exciting pics to come as progress is actually made.
Any tips for painting this? Of all the work to be done - that's the one part i dont look forward to. I also want to integrate the A pillar and main hoop to the chassis. Dont know what i'm going to do with that yet.
What gauge sheet to use for spreader plates? I have 16 ga right now but i am not sure if i should go thicker or not. Stock sheet is probably 18 or 20ga - not extremely thick. (should probably read the rules, eh? i am right in my tubing selection and design so far, but i didn't see the part about spreader plates except for 9sqin or more for harness mounting points)
edit: just heard the spreader plates need to be 1/8". ugh. that's gonna 1. be expensive 2. be a bitch to weld to the floor pan.
Finished removing bits from inside this evening - then used an air chisel (my god i love air chisels) to remove the rest of the tar mat that was under the center console i never got around to removing before. Cut that goofy angle bar from the diagonal. This weekend i might cut the diagonal, but i might just reweld it. It's plenty strong but the welds dont look super. I figure zippy wheel then hit them with the TIG torch and maybe add filler if need be.
Roll bar padding... is the pmzracing stuff decent? it's much less than the other racing sites.
