nathankershaw wrote:Frustrating day today. All little bits that I have put off doing now need to be done, it felt like it was one step forward and two steps back.
I know that feeling. It feels like it takes 80% of the time to do the final 20% of any custom project.
Yeah little bits of wiring are the slow bits now. Then take it all out and make it look pretty.
Went down today and met Brett (GRVE66) and got a few goodies. He is an awesome guy with such a nice car that met an unfortunate end.
The exhaust that will be stored until after the BAR test.
and these compression struts. These may come in handy if the BAR say my CATS are too far away from the manifolds, as right now the sway bar gets in the way.
One's bent which will need fixing.
Took my wife for a quick spin around the block tonight. It was awesome span the tires and the homemade driveshaft is holding up as of now, that's a finger crossed situation! lol!
She's was a combination of freaked out she could see the floor through the tranny tunnel and happy with what I had done.
With the V8 being a little heavier I waned to keep some weight off the frone so I chopped the top section out of the Jetta bumper crossmember and welded it to my crossmember.
The sides are seeing some ziptie action for now until I feel like making some brackets.
I also made an adapter so my after market water temp gauge can go in the small thermostat water hoses.
Thats actually not the issue right now. The probe itself isn't seating down so isn't pushing back and sealing against the outer lock ring.
I didn't know it had to!
Learn something new everyday!
Did a little bit more
soldered in a CEL to where the brake pad warning light used to be, I need to get a symbol now and stick it in place.
Dash is back in
And front is on
