Does anyone have to feather the fuel into there tanks? Even one steady notch on the pump handle is too much for both my xr's. I believe it is due to too many baffles in the filler neck of the tank. Is there a remedy? I'm sick of smelling like gas when it pukes onto my hand and having to hold the trigger in freezing weather.
Mike
Fuel delivery problem, from the gas station pump.
- Level 2
- Mike McCreight
I don't think it's baffles as much as it is venting.. Some of my XRs drink at full throttle at the pump, and some like to sip it. I usually just jam the fuel cap in the handle. After I remove that annoying tether that is...
- John R. Rowlands
mikerobison,
Clean your fuel tank vent, that should eliminate the problem.
John
John
