Re: My Build Thread: Project "Rain Cloud"
Post by hEaT » Wed May 29, 2013 8:56 am
Thanks and sure, go for it! If you're running trim and carpet in the hatch, you may find a better location for it. This works for me since behind the rear seats, only the side trim panels are going back in.
For fuse and wire, look into this stuff:
http://www.knukonceptz.com/productMaste ... ks%20Kable
http://www.knukonceptz.com/productDetai ... odID=FH-20
http://www.knukonceptz.com/productMaste ... ccessories
My short ground run is 0 gauge, the power wire to the front is 4ga. If staying with the stock starter, you'll probably need to run a separate wire to the front and a solenoid at the battery for the starter. If running a mini-starter (the route I'm going to go) a 200A fuse should be okay.
In XS 7
Post by In XS 7 » Wed May 29, 2013 3:01 pm
Thank you Joe,very nice of you, and thanks for all the info.
Your thread is very informative, full of great ideas and solutions, as well as helpful mods.
I am learning A LOT :thumb .
Post by hEaT » Wed May 29, 2013 5:33 pm
In XS 7 wrote:Thank you Joe,very nice of you, and thanks for all the info.
:cheers
That's how I learned too. Just reading threads, getting ideas, and putting my twist on it.
Post by Ray » Fri May 31, 2013 5:33 pm
Hey joe - i like white LX's idea - run dual solenoids, bleed switch off the ignition starter switch to solenoid near battery. Wire's only hot on KOIOSO - makes sense. Still, i'm a major fan of fusing everything, but that's a much cheaper option than going with a mini starter.
Post by hEaT » Wed Jun 05, 2013 6:45 pm
Ray wrote:Hey joe - i like white LX's idea - run dual solenoids, bleed switch off the ignition starter switch to solenoid near battery. Wire's only hot on KOIOSO - makes sense. Still, i'm a major fan of fusing everything, but that's a much cheaper option than going with a mini starter.
Does make sense, but is much more wiring and does leave a wire unprotected during cranking.
mc2 mini-starter delivered today and got some extra wire and terminals to reinforce my engine/chassis grounds.
Post by hEaT » Sun Jun 09, 2013 10:47 pm
Lots of pics for very little work this weekend. I'm getting more comfortable wiring, it's fun.
New starter, ended up wiring it differently than seen here:
Yes...it's smaller and less amp draw which was the main goal:
Old starter cable was fine, but I had some 4ga so...why not? Also a ring terminal works better than the odd square on the old cable:
In and wired up. Constant 12v goes from the constant hot side of the old starter solenoid (my new distribution block) to the constant hot side of the solenoid. Switched side of the older starter solenoid goes to the mini starter solenoid switch. When I run out of things to do, I'll put a dedicated distribution block on the fender and use the old solenoid trigger for the mini starter, eliminating the old solenoid completely. For now, this works fine.
Had to shim the starter away, washers are temporary for now:
New ground point and distribution:
Got an actual hold down for the battery:
catapultkid
Post by catapultkid » Mon Jun 10, 2013 1:21 pm
Looks good! I'm happy with it so far and weighs much less.
-Paul
'85 Merkur XR4Ti
K20, VW mk2
'89 K2500, 6.0 swap
'00 Honda Insight
Post by hEaT » Mon Jun 10, 2013 3:23 pm
catapultkid wrote:Looks good! I'm happy with it so far and weighs much less.
Thanks! Did you have to play with any shims on yours or bolt it up and go?
Post by John Brennan » Mon Jun 10, 2013 3:49 pm
Curious as to why you had to shim out the starter. Is this the normal procedure with these?
Post by hEaT » Mon Jun 10, 2013 6:16 pm
John Brennan wrote:Curious as to why you had to shim out the starter. Is this the normal procedure with these?
Normal is what I want to find out. After I installed it bolted as normal the starter would grind for a second after I released the key. It could have also been due to the wiring which I can easily change and test (had it wired as factory and the solenoid switch on the same node). I did some reading over on Corral.net and it seems it's common to shim them out for the same issue.
catapultkid
Post by catapultkid » Wed Jun 12, 2013 10:27 pm
I just bolted it up and went. Doesn't stick at all, only thing I dont like (and may be due to the program timing or bad tfi) is that it seems to jump timing when cranking and be a little harse on the starter. I'm a bit worried about it.
-Paul
'85 Merkur XR4Ti
K20, VW mk2
'89 K2500, 6.0 swap
'00 Honda Insight
Post by Esteban » Thu Jun 13, 2013 1:16 am
I didnt have to shim mine either. You may want to double check the wiring. You should still use the stock solenoid in conjunction with the new relay on the starter.
Post by hEaT » Thu Jun 13, 2013 8:18 am
It currently is wired up with the stock solenoid switching the solenoid on the starter. I'll double check this weekend if it still does it without a shim.
Do both of you guys have T5s or T9s? The block plates are different between the two which also may be why.
catapultkid
Post by catapultkid » Thu Jun 13, 2013 8:40 am
I've got a T-5.
-Paul
'85 Merkur XR4Ti
K20, VW mk2
'89 K2500, 6.0 swap
'00 Honda Insight
Post by hEaT » Mon Jul 08, 2013 10:59 pm
Confirmed with the proper wiring (constant 12v to the starter motor, switched power to the solenoid) no spacing is needed. If switched power is sent to the starter then a spacer is needed.
Also, got this in. This is a bit beyond my skill level so my only involvement here was in the design. Had good friend of mine laser this out for me and weld it. I like doing my own work, but I couldn't say no when this is the finished result.
No pictures in car, but goes where the battery was and is held down with the old battery tie-down bolt. Three front bungs will be plugged for now, but will allow relocation of the ECT, gauge sender, and an aftermarket temp gauge sender if needed.
