Some more details with pics.
Parts:
Scorpio front hub assembly (should have identical offset as XR)
2005 Focus Rotor
2012 Focus Caliper
Qty 4 1/2" galvanized washers from Home Depot. That's just a miniscule bit too much, so if making a spacer, call it .160" instead of the .180" as shown by stacking two washers. This dim' doesn't need to be ultra precise - maybe look for some slightly thinner washers.
- FocusBrakes-1.JPG (977.02 KiB) Viewed 3064 times
- FocusBrakes-2.JPG (979.4 KiB) Viewed 3064 times
- FocusBrakes-3.JPG (985.87 KiB) Viewed 3064 times
- FocusBrakes-4.JPG (1.06 MiB) Viewed 3064 times
- FocusBrakes-5.JPG (1.03 MiB) Viewed 3064 times
- FocusBrakes-6.JPG (1014.43 KiB) Viewed 3064 times
- FocusBrakes-7.JPG (1.08 MiB) Viewed 3064 times
Note that the Scorpio hub will need to be re-drilled for the 4x108 bolt pattern which I plan to stick with (too many 4x108 wheels around here). I've already bored out the mounting holes to 14mm to use the 2012 Focus bolts. They almost work fine but for the flange on the bolt head being just a bit too big - it reaches out past the machined flat on the knuckle casting (if you look close you can see that in the back-side pic above, just on the right mounting ear). I'll find a bolt with a smaller flanged head, or just one without any flange at all. I suppose the better approach would be to surface cut the mounting surface just a little wider.
The pad does really track out to the very edge of the rotor. In an ideal world the rotor would be maybe 2mm wider, but this will be fine. The upside is that you won't have any issues pulling the caliper off a worn rotor with a ridge around the rim.
And yes, if using the Scorpio knuckle assembly you also need to figure out the strut situation. That topic has been covered in here a couple different ways - I'll be using Mk4 VW Jetta struts.
