PCV Valve?
alexob53
PCV Valve?
Post by alexob53 » Fri Jan 22, 2016 3:48 pm
Hello everyone! My xr has recently developed an oil leak, and I just pinpointed it to the crank seal or some other front end seal behind the timing cover. I have read that PCV valves can pressurize the engine, causing seals to blow out, which would make sense in my application because it seems to be leaking a decent amount, and after I turn the car off I can hear it bubbling out of the seal. I went to check the PCV valve, but I could not find it. I am looking right behind the alternator and in between the head and the distributor. There is a mysterious looking hose-to-hose connection where it might have been before, so I took photos and uploaded them here. I think the previous owner may have deleted the valve. Does anyone know if this is possible or what he might have done? Thank you!
88 Merkur XR4Ti manual
90 Chrysler TC by Maserati 16V
00 Mazda MX-5 Miata LS 5-speed
01 Dodge Ram 2500 5.9 Cummins 5-speed
08 Smart Fortwo
08 BMW 135i Cabriolet
Re: PCV Valve?
Post by hEaT » Fri Jan 22, 2016 3:54 pm
Pull that apart. It looks like he may have hose clamped onto the PCV since it fits there into two different sized hoses.
Regardless, get yourself an OEM ONLY Motorcraft EV127A valve. Nothing else. No parts store brand stuff.
Is it blowing any oil out the dipstick?
alexob53
Re: PCV Valve?
Post by alexob53 » Fri Jan 22, 2016 4:18 pm
Thank you! Update: The PCV valve, as you pointed out, is not Motorcraft. It does work, however, and neither the valve or the hoses are clogged. Could the breather cause a leaky seal as well?
08 Smart Fortwo
Re: PCV Valve?
Post by hEaT » Fri Jan 22, 2016 4:57 pm
alexob53 wrote:Thank you! Update: The PCV valve, as you pointed out, is not Motorcraft. It does work, however, and neither the valve or the hoses are clogged. Could the breather cause a leaky seal as well?
It could, but I would replace the PCV valve anyway. I had one that worked great by hand...but blew oil everywhere when in the car.
alexob53
Re: PCV Valve?
Post by alexob53 » Sat Jan 23, 2016 12:18 pm
Very well, I will replace with a motorcraft part! To check the breather, should I just remove it and look for a clog?
08 Smart Fortwo
Re: PCV Valve?
Post by hEaT » Sat Jan 23, 2016 12:45 pm
alexob53 wrote:Very well, I will replace with a motorcraft part! To check the breather, should I just remove it and look for a clog?
On the valve cover? I'd remove it and spray brake cleaner through.
alexob53
Re: PCV Valve?
Post by alexob53 » Sat Jan 23, 2016 5:38 pm
I checked the breather and everything seems to be working properly. I ordered the Motorcraft part to replace the PCV, just so I know it's not a problem. I am thinking it might be that the seal/gasket is leaking simply because it is old. I'm going to replace the front crank seal and front cover gasket as well as the cam seal, and while I'm at it I might replace the valve cover gasket with the upgraded ranger one.
08 Smart Fortwo
Choochoochoo
Re: PCV Valve?
Post by Choochoochoo » Sat Jan 23, 2016 6:56 pm
Just a heads up on the upgraded ranger valve cover gasket, it isn't cheap. I called my local ford dealer to get one, $65.95, and he would've had to order it. I just went with a rubber fel pro one instead.
2008 Mercedes Benz R320CDI
1985 Merkur XR4Ti
85xr
Re: PCV Valve?
Post by 85xr » Sat Jan 23, 2016 10:58 pm
check the junk yards for the ranger valve cover gasket. just look for a good one.
greg
Re: PCV Valve?
Post by John Brennan » Sun Jan 24, 2016 1:53 am
Choochoochoo wrote:Just a heads up on the upgraded ranger valve cover gasket, it isn't cheap. I called my local ford dealer to get one, $65.95, and he would've had to order it. I just went with a rubber fel pro one instead.
You'll never need another. Sometimes it's good to spend a bit more for the right part. This is one of those times.
alexob53
Re: PCV Valve?
Post by alexob53 » Sun Jan 24, 2016 1:11 pm
I found a Ford OEM gasket for the 2.3 ranger on amazon for $50 + free shipping. I will probably order that one, but if it doesn't work out there is a salvage yard I could check without much trouble. Thanks for the heads up and ideas!
08 Smart Fortwo
