NEW aluminum coolant pipes available for the XR4Ti.
This is the top pipe that runs along side the valve cover, we have many options and finishes available.
85-88 stock replacement.
89 specific with the port deleted for the passenger side coolant bottle.
85-88 with water port deleted for the turbo.
Great to remove the unsightly factory capped port on the 89 XR, or the hose with a bolt stuck in it, for those running a Holset or other oil-only turbo.
Raw finish can easily be painted black to have a factory looking appearance, or if you like shiny things we also offer all variations in a mirror polished finish.
Direct link:
http://merkur.50megs.com/catalog_2.html
NEW XR4Ti Aluminum Coolant Pipes Available
Moderators: John Brennan, DPDISXR4Ti
- merkurdriver
- andyofcolumbusmerkur
Re: NEW XR4Ti Aluminum Coolant Pipes Available
Any timeline on (or if) you will get anymore in stock?
'88 Merkur XR4Ti-The Build (need to get back to working on)
'87 Merkur XR4Ti-The Beauty
- merkurdriver
NLA for a while and I doubt any more will get made until after summer unfortunately.
