NEW Full Aluminum Heater Core with -10AN fittings
Special deals from our sponsoring vendors.
Moderators: John Brennan, DPDISXR4Ti
Direct replacement / upgrade for the stock heater core with plastic tanks.
-10AN fittings for inlet / outlet
Only 1 available in this configuration with AN fittings
https://www.ebay.com/itm/203122769694
salukixr4ti
Re: NEW Full Aluminum Heater Core with -10AN fittings
Post by salukixr4ti »
Look at that beauty!
This ain't no disco...It's Wichita.
Side exit -10AN fittings for inlet / outlet routing behind the dash. Exit the firewall in an alternate location.
Great set up for engine swaps when the stock heater core tubes end up in an inconvenient spot with the new engine in.
Only 1 available in this configuration with AN fittings:
https://www.ebay.com/itm/NEW-Ford-Sierr ... 3225270571
Only a handful made in this configuration.
https://www.ebay.com/itm/204466549219
Heater core side AN.jpg (312.25 KiB) Viewed 52539 times
Heater core side ANbox.jpg (248.67 KiB) Viewed 52539 times
