Here is some reference material, for dremel crafting.
Lay string along each bend in the hood, and use more string to get these dimensions in place. Could have gone an inch or two wider on both sides, but preference.
The 7" mark really should be 9" or a little over, to drop the opening just behind the radiator.
XR center hood vent DIY
- Attachments
- 20230708_045857.jpg (1.32 MiB) Viewed 7733 times
Re: XR center hood vent DIY
I cut the front section, ~2-1/2 ", and got it angled to match the front of the hood. Found a roll of tin, around 4"-6" diameter, and slightly bent the rear section to my liking.
Welded in some side sections, bondo, sand, prime.
- Attachments
- 20230903_041234.jpg (1.2 MiB) Viewed 7732 times
- 20230903_041206.jpg (1.21 MiB) Viewed 7732 times
- 20230903_041154.jpg (1.11 MiB) Viewed 7732 times
- andyofcolumbusmerkur
The Merkur purists are going to be mad at you.
- merkurdriver
Looks purposeful. Heat extraction for the intercooler?
