RockAuto Scorpio Closeouts Direct Link
Re: RockAuto Scorpio Closeouts Direct Link
brokencase wrote: Wed Sep 13, 2023 10:27 am If those then why not these?
https://www.ebay.com/itm/234424466829
Strange...That's the link I intended to copy and paste. I should have checked it before Submitting as I had several links on my Clipboard.
[/quote]Do you feel that you need new injectors?
[/quote]
Don't think so. The '89 probably hadn't received any injector cleaner over the many years of original owner's driving. I base that on tail pipe sounds at idle. I've added injector cleaner (SuperTech Concentrated) at every fill up since I've owned it. Exhaust now burbles (kinda spit/coughed a bit before), and performance also picked up to.where I doubt it needs any further mprovement. So I'm good.
The price of those blue ones is so much less than a quality injector cleaning and testing with two-way postage service it's appealing just to add a set to my stash.
Post by brokencase »
I think I am more worried about the O-rings failing then the injectors themselves.
I'll bet the only issue you will find with the stock injectors is a sooty build up on the injector face and you can clean that up yourself.
There is the claim that the later 4 hole injectors atomize better. But the Scorpio's injector shoots against the valve port, sometime even against a closed valve, so the stream gets atomized pretty good anyhow.
brokencase wrote: Thu Sep 14, 2023 1:47 pm I think I am more worried about the O-rings failing then the injectors themselves.
I'd bet an external leak from an injector itself would be more probable than an O-ring issue. There have been several reports of XR injectors leaking (higher underhood temps) while I've not heard of that occurring on Scorpios.
^^ That discounts failure to either consistently without fail use only gasoline from Top Tier retailers, and/or frequently add quality fuel injector cleaner to fill-up to address typical crud build-up in fuel systems.
https://www.toptiergas.com/
Yeah, I here ya, but it is a pintle valve. The orifice itself is pretty much self clearing. A pin matched to a hole. Probably the real advantage to a "single hole injector"
Those 4 hole injectors are probably more prone to clogging.
It's the deposits on the external face that screw up the spray pattern over time. There was a guy on this board that rebuilt a tired old 2.9L and put it into an XR4ti. I asked him what did the injectors look like and he said they were fine.
Injectors are way down on the bottom of my list of things to be worried about. I ran a bottle or two of Techron when I first acquired the car. Only because it was an unknown.
Even this is probably more than I should have thrown at this non-issue. I don't think spares will ever become "unobtainium" in my time.
I'd have to run into a situation where, without a doubt, a failed injector is determined culprit before I go and change them.
Couple good deals popped up on RockAuto Scorpio Clearance section.
https://www.rockauto.com/closeouts/?car ... seoutEmail
Power steering pump $22.79
K&N PS2004 Pro-Series Oil Filter $2.49
I notice a couple more goodies on RockAuto Scorpio closeouts!
Rear hatch lift support $7.55 <-that is a good deal! I spent a bit more to change mine last year.
Rear left halfshaft for $31.79
Oil pressure sender $1.82 <-that is a good deal! Mine failed and I spent $15 to replace.
Of course the $2.36 K&N Oil filters are still there as are the under $17 water pumps.
