T-5 Conversion Parts List & Source
This may exist somewhere, but I haven't found it. I'm just trying to compile a concise list of the actual parts needed/advised for a T5 conversion, and note sources for them. I'd appreciate any contributions to this post - I know I've missed stuff.
I will refine this post after feedback, and hopefully add contact information - which IMHO is key. Hunting these things down on the net is a PITA.
Bell Housing: Any T5 bellhousing from any cable clutch 2.3l car - Mustangs, Capris, etc.
Transmission: Any T5 transmission - but 2.3l Fords already have the proper input spline size. Other T5s will require "adjusting." Output splines are all identical amongst T5s
Flywheel & Clutch: Any 2.3 + T-5 equipped Ford
Clutch pedal: Manual XR4Ti clutch & brake pedal assembly, making note of "early" vs. "late" tunnel widths
Clutch quadrant: Manual XR4Ti or David Godfrey's aluminum one
Clutch cable: Manual XR4Ti or Mustang. The XR4Ti cable requires an adapter (below) to connect to the T5; the Mustang cable requires "modification" to the included nylon sleeve to pass through the XR4Ti's firewall.
Clutch cable dogbone adapter: Richard Thompson (necessary in order to use the XR4Ti clutch cable with a T-5 transmission)
Driveshaft: Any T-5 Mustang/Capri with a driveshaft adapter, or the factory XR4Ti 2-piece driveshaft that's been shortened and "mated" with the T5 input side
Driveshaft adapter: 460 Machine Shop or Galaxie1 - necessary if using the 1-piece Mustang driveshaft
Transmission crossmember: Galaxie1's part, or who the heck is rwolfe on
ebay?
Transmission mount: Standard T5 mount with aforementioned transmission crossmember.
Speedo cable: An automatic XR4Ti - early XR4Tis use a one piece speedo cable, while later ones use a 2-piece. If you see a "coupler" at the false bulkhead, you've got a later car. You must use the appropriate cable for your car. You will also need to cut the nub off the end of the gear to allow it to seat in the T5.
Speed Driven Gear: For the T5 transmission - a 6-tooth is preferred. A 7-tooth will only work out if you've got a 3.36 rear-end.
Does this all sound right? Can anyone provide contact info (preferably websites AND email) for:
o David Godfrey
DGodfrey@DRS-TEM.com
o rwolfe
o Galaxie1
o 460 Machine Shop
Sandra K. Wallace
V.P. Operations
460 Machine Company
3830-A-Corporate Road
Petersburg, VA. 23805
(804) 861-8787
(804) 861-8766
Or see their web site http://www.460machine.com
o Richard Thompson
rt@merkurxr4ti.com
http://www.merkurxr4ti.com
conversion write up for swap to C3 to T5 at MerkurTech.com:
http://www.merkurtech.com/merkurtech/te ... tem038.php
Thanks!
ebay?
o David Godfrey
o rwolfe
o Galaxie1
o 460 Machine Shop
Sandra K. Wallace
V.P. Operations
460 Machine Company
(804) 861-8787
(804) 861-8766
o Richard Thompson
rt@merkurxr4ti.com
Thanks!
Don Haulsee doesn't sell his adapter. He sold the manufacturing rights to it to 460 Machine a few years back.
Contact
Sandra K. Wallace
V.P. Operations
460 Machine Company
(804) 861-8787
(804) 861-8766
Contact
Sandra K. Wallace
V.P. Operations
460 Machine Company
(804) 861-8787
(804) 861-8766
Mark
Re: T-5 Conversion Parts List & Source
does this mean a t9 to a t5 conversion requires the automatic speedometer cable with the t5 gear?thesameguy wrote:Speedo cable: Any automatic XR4Ti, plus the proper T5 speedo gear
You can use the auto cable as is. You just have to cut the nub off the end of the gear, or it won't seat all the way in.demonfire wrote:does this mean a t9 to a t5 conversion requires the automatic speedometer cable with the t5 gear?thesameguy wrote:Speedo cable: Any automatic XR4Ti, plus the proper T5 speedo gear
Tony Vissoc
Nothing to see here. Move along.
As long as we're talking speedo cables, bear in mind that several different types were used on the XR, depending on the model year and whether cruise control was present. If you're doing an automatic to T5 conversion, you really don't need to be too concerned - you just re-use whatever you've got and swap in the appropriate speedo driven gear onto the end of the cable. If you're doing a T9 to T5 conversion, you need to figure out what type of speed sensor you have, and/or if you want to keep it at all.
Bear in mind too, you need to know what speedo drive gear you have in the T5 to determine which driven gear you'll need. A 6-tooth is preferred. A 7-tooth will only work out if you've got a 3.36 rear-end.
Can you briefly expand on the cruise control scenario? I'm aware of the two major speedo cables (I added that bit) but I have no info on cruise control... this is I think the first I've heard of it!DPDISXR4Ti wrote:As long as we're talking speedo cables, bear in mind that several different types were used on the XR, depending on the model year and whether cruise control was present. If you're doing an automatic to T5 conversion, you really don't need to be too concerned - you just re-use whatever you've got and swap in the appropriate speedo driven gear onto the end of the cable. If you're doing a T9 to T5 conversion, you need to figure out what type of speed sensor you have, and/or if you want to keep it at all.
Two different speed sensors were used. Cars built through ~3/88 had the speed sensor attached to the back of the cluster and I believe they use the same cable as the non cruise-control cars. Cars built after 3/88 use a speed sensor mounted on the false firewall, which connects via 5/8" threaded fittings on both sides. As a result there's a ~1 foot long cable that goes between the speed sensor and the cluster. I greatly prefer this setup (even though I've removed CC), as it makes cluster removal a snap (just unscrew the fitting at the false firewall).thesameguy wrote:Can you briefly expand on the cruise control scenario? I'm aware of the two major speedo cables (I added that bit) but I have no info on cruise control... this is I think the first I've heard of it!
Hope that makes sense.
Pretty much correct. I guess I'd call it cables, given that most (all?) of the late cars had cruise control. But the short cable from the cluster to speed sensor would be the same regardless of tranny type, so in that sense, yes, you'd just need the C3 to speedo sensor cable.thesameguy wrote:Aye... it makes sense. But, does this not mean that if you're converting a post 3/88 car from a T9 to a T5, you just need the speedo cable from an automatic post 3/88 car?DPDISXR4Ti wrote:Hope that makes sense.
It's not as confusing as it sounds, once you see it all in front of you. I actually had to somewhat fabricate my own cable, since the metal end that goes in the C3 is often seized in place and the cable sheathing simply pull away. I salvaged a "new" fitting end from a '80 Mustang and attached that using some RTV and hose clamp.
No, I understand perfectly. I took apart an '89 XR4Ti and saw first hand what you're referring to. It's just when I read your original post I thought I'd missed something, and began concocting an image in my head that was way more complex than the reality.DPDISXR4Ti wrote:It's not as confusing as it sounds, once you see it all in front of you. I actually had to somewhat fabricate my own cable, since the metal end that goes in the C3 is often seized in place and the cable sheathing simply pull away. I salvaged a "new" fitting end from a '80 Mustang and attached that using some RTV and hose clamp.
BTW, this might be me. if so, I am honored to be confused with David Godfrey, but unfortunately, I am out of those clutch cable adapters that I had made up. I might have a crack at another batch, but it won't be in the next month or so.Clutch cable dogbone adapter: David Godfrey (necessary in order to use the XR4Ti clutch cable with a T-5 transmission)
Richard
