DSP to SM build
Re: DSP to SM build
Post by Ray »
Ben, to answer your question - no, i do not have a shimmy. I am using the (gasp!) rubber trans mount, single piece D/S, those hard motor mounts, rear is solid mounted with nylon STA bushes. Front has those "black" edition poly bushes that grayson got us. Using heim joints for top mounts for all dampers.
Under high boost - what is "high boost" and i'm having trouble envisioning this shimmy.
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
Ray wrote:Ben, to answer your question - no, i do not have a shimmy. I am using the (gasp!) rubber trans mount, single piece D/S, those hard motor mounts, rear is solid mounted with nylon STA bushes. Front has those "black" edition poly bushes that grayson got us. Using heim joints for top mounts for all dampers.
That's ok I'm thinking it could be 2 things, 1 is the clutch, 2 maybe the right engine mount, Changing both next week.
18lbs at 3200rpms is high boost for me.
I'll have Chris drive my XR at the National's and ask him what he thinks.
Ben
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
Drove the 90 sec course today, I don't have the results yet but will put the results up when I get them, what a day, I had a lot of trepidation when I was driving out to this event, thinking about what I've done to the XR over the last 2 weeks.
Change left rear toe out by -1/32 or .014 shim
lower and change the rear springs back to the 700lbs because I have a 55% to the front and 45% to the rear.
Replaced both shock to new ones.
Did not change the front toe like I though I would, because I said what the hell.
Corner weighed the car.
Lots of little thing that really don't help in the handling of the XR but help with the weight. Great day I know I'm going to sleep well tonight.
Going out right now to weigh the XR to double check and make sure I'll make weight for the National's.
Ben
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
http://www.youtube.com/watch?v=tQSNsy_4UcU
This is vid from the 90 sec course.
Ben
Re: DSP to SM build
Post by Esteban »
Geezus! Driving in xp feels like piloting a jet fighter!
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
DAReese
Re: DSP to SM build
Post by DAReese »
I like the Miata with the graphics of the cones flying all over the place.
nathankershaw
Re: DSP to SM build
Post by nathankershaw »
Car looks great!
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
Street Modified
Go to Class...
Index: 0.867
Ben Martinez 1. 84.968 2. 83.794+1 3. DNF
Karlton Lew 86.964 + 7 85.723 DNF
Takeshi Yoshida 88.584 105.048 + 1 87.451
Josh Salvage 89.448 +3 88.484 +1 88.575
Kramer Weydt 92.636 +1 DNF 89.505
Xr4ti
Toy Supra
EVO
EVO
240sx
Can I say a great event, can't wait for the National's.
Ben
catapultkid
Re: DSP to SM build
Post by catapultkid »
Dam man. So happy you've gotten this sorted and ready. Wish I could be there to see you dominate the year.
-Paul
'85 Merkur XR4Ti
K20, VW mk2
'89 K2500, 6.0 swap
'00 Honda Insight
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
catapultkid wrote:Dam man. So happy you've gotten this sorted and ready. Wish I could be there to see you dominate the year.
I don't know about Dominate but it's going to be a great battle. HeHeHeHE!!!
Ben
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
Had A double event this weekend, Lotus club had a great event that was fast but YOU had to look ahead a lot, XR worked just like it did at crows landing and their was a 6 time SS National Champ there and got that car by .700, don't know if that's enough but the XR feels great.
Next went Oakland, the course look great when I walked it but by the 4th run group the surface was bad, so I felt like I was driving the rain, learn a lot.
Things to do:
Check the weight to make so I'll be ok
Check alignment
Change oil
bleed brakes again
make "L" bracket for seat
Pull a small wire through
Steel ball in the PVC
Clean the XR inside and out
Mount up rain tires
Go win the National's, That's all.
Ben
In XS 7
Re: DSP to SM build
Post by In XS 7 »
:headbang Wow Ben that's awesome, congrats and I am wishing you the best for the Nationals. :wink: :thumb :cheers
DSPXR4ti
Re: DSP to SM build
Post by DSPXR4ti »
In XS 7 wrote::headbang Wow Ben that's awesome, congrats and I am wishing you the best for the Nationals. :wink: :thumb :cheers
Thank you. I going to have fun.
Ben
catapultkid
Re: DSP to SM build
Good Luck this week Ben! Take it too them. I'll be watching the results
-Paul
'85 Merkur XR4Ti
K20, VW mk2
'89 K2500, 6.0 swap
'00 Honda Insight
