headlights on no left turn signal
austen
- Newbie
Just got the turn signals to work on my '89 automatic; now with parking and/or headlights on the left turn signal does not work; it works without lights on; right turn works all the way. Wrong bulb? Ideas? Thanks
salukixr4ti
Signal stalk
You'll find a few things to check are:
1. The signal stalk's hazard switch. They are failure prone, and cause what you're describing. The internal mechanism turns to crap. Sometimes you can work it out- sometimes not. If your car has cruise, and you intend to keep it, start looking now for a spare stalk - they're getting rarer. If no cruise - no problem finding a new replacement, but prepare to pay either way.
2. Bad grounds
3. Oxidized bulb sockets
My money is on the stalk...
2. Bad grounds
This ain't no disco...It's Wichita.
Check the bulbs in your LH tail light housing.
I foolishly chased just such a problem on a friend's car, ASSuming he knew enough to check that he had the right bulbs in there...
austen
- Newbie
This guy had a 1056 where an 1157 should have been. Shorted the brake light into the marker lights.
You could also have a short in the wiring connecter. Pull it off and have a good look.
austen
- Newbie
salukixr4ti
OEM Light chart per Owner Manual - 1986
9004 Headlight
904 Parking lamp
880 Fog lights
1157 Front turn signals, Stop lamps (outboard only)
168 Side marker lamps (all)
1156 Rear turn signals, Back-up lights, Stop lamps (inboard only), Engine compartment light
1816 License plate lamps
912 High mount stop lamp
89 Dome & luggage compartment
168 Map lights
194 Glove box
37 Ash tray
904 Parking lamp
880 Fog lights
168 Map lights
194 Glove box
37 Ash tray
austen
- Newbie
CV12Steve
