Aux. shaft bearings
topher_csr
- Level 3
Aux. shaft bearings
has anyone replaced the bearings on their aux. shaft. this is the small shaft that the distributor runs off of. i replaced mine today and i now cannot put the shaft back in. i think i am going to hone the bearings tommorow. i also had a hard time finding them because ford is no longer making them. let me know if anyone else has ran into this problem.
86 xr4ti-
Front Mount Intercooler, Turbonetics Super 60 Turbo, External Wastegate, XS Power Exhaust Manifold, Intake, 3" downpipe, LB2 and big VAM
All kids play with cars, the unlucky ones grow out of it.
86 xr4ti-
merk23literturbo
topher_csr
- Level 3
i used a bearing driver. the install was not the problem as much as the overall size of the bearings. i think i am going to hone them out tommorow.
86 xr4ti-
86 xr4ti-
Chuck W
The bearings should be the same as the cam bearings IIRC.
I don't think honing would be a good idea.
thrashperformance
either the bearings are two different sizes and you have them in the wrong order(i dont think that is possible but cant remember) or you boogered one or both of them putting them in. get a cam bearing installer and you will not repeat the problem. the tool can be spendy so maybe you want to borrow one.
jake nawrocki
1 cor 9:24
"if its not broke, i can problably still fix it"-tim allen
1 cor 9:24
merk23literturbo
Well since no one else answered yet...
Don't hone the bearing to make it fit. Pull out the bearings, get a new set and put them in with the correct tool. You can test fit them onto the aux shaft to be double sure that they are the right part. If they are right and it binds then you didn't put them in perfectly straight, which they have to be.
Good luck.
Good luck.
James Wieler
Aux. shaft bearing removal in car
Hi Chris,
How did you remove the old bearing? Does it pull out or drop down into the oil pan using a drift?
Anyone?
thanks
James
Anyone?
thanks
James
Cossy sway bar, Powerflex, Dynalites, Focus SVT rotors,Koni yellow sleeve over 8"x300lb/in springs,Scorch bumper cover, 17x7.5x40mm Binno wheels, 225/45-17 Kumho 712 tires
