While I continue to collect parts for my power steering project I decided to solve another problem that the car has - the magical, sluggish, low-reading XR4Ti tachometer. I decided to resolder all the connections on the circuit board inside the tach. Here are pictures and a write up to go with it.
Removing the gauge cluster only requires a phillips head screw driver and perhaps a pair of pliers if the boost gauge vacuum line is difficult to remove.
- remove steering column top trim (1 screw)
- remove steering column bottom trim (3 screws)
- remove turn signal switch stalk assembly (2 screws)
- remove wiper/head light switch stalk assembly (2 screws)
- note that the thin metal bracket on the top will come loose with the top screws of each of the switch stalk assembly
- remove the gauge cluster surrounding trim (4 screws, two on the bottom next to the steering column, two on the underside of the top near the sides)
- pull the gauge cluster surround straight away from the dash a short distance to reach up behind from underneath and either pop the gauge bulb dimmer and wiper interval controls out foward and unplug the harness or unplug the wiring plug from the back of the control without popping it out; this will free the black gauge cluster surrounding trim
- remove the gauge cluster from the dash (4 screws)
- the gauge cluster will be held in place by three things:
-- the speedometer cable
-- the boost gauge vacuum line
-- the wiring plug
gauge cluster pulled forward and flipped upward (speedo cable disconnected, wiring connection visible and boost gauge vacuum line visible)
The speedometer cable has to be removed first because it has the least play of the three connections. To do so, pull the right side of the gauge cluster out enough to reach behind the cluster. The cable is held onto the gauge by a plastic slip ring:
- apply pressure to one side of the ring to pop the cable free
- apply pressure to the portion that has grooves molded into it
plastic slip ring on speedo cable (apply pressure from the right as viewed in this picture)
See the grooves? Push there!
you can see the plastic tab on the inside left of the metal cylinder which grabs the notch in the back of the gauge
backside of the gauge cluster
- remove the screws from the backside of the gauge cluster along the perimeter to separate the front and back halves (5 screws)
front side of gauge cluster
- carefully remove the foam trim around the gauges; note that it has a very thin cross section in many areas which may tear easily
foam trim
- remove the three 7 mm nuts and their copper locking washers from the backside of the tach; if you have the IVR add-on board, note which stud the black wire connects to
tach free of the gauge cluster
tach-less gauge cluster
- with the tach free of the cluster, remove the boost gauge and tachometer needles, BUT FIRST:
-- take note of the needle position, and
-- take note of the offset of the needles from the gauge face
... if you don't, the tachometer may hang up and not operate smoothly
tach needle offset
needle position
- remove the gauge face by removing the screws at the top left and bottom right of the tach as seen in this picture (2 screws)
gauge backside
- with the gauge face removed, the boost gauge needs to be removed with a 14 mm deep well socket (and you thought you'd NEVER use that thing on your XR4Ti)
boost gauge nipple and nut
The boost gauge has to be removed because it sits right in the middle of the circuit board you are about to remove and resolder.
boost gauge mechanism and circuit board
there is literally a hole through the circuit board for the gauge
With the boost gauge removed, the tabs holding the circuit board in place should be manipulated in order to get the circuit board out. You can see that I broke one of the two tabs off.
upper left tab missing, lower tab in place
Here's a quick detour about the boost gauge. It's a ridiculous contraption made of a small, thin, curved pressure vessel that deforms when the pressure inside of it changes. That curved thing around the outside isn't a spring,
it's the gauge mechanism!
boost gauge mechanism with the needle on for posterity
side view
back view
Note the threads inside the nipple... at one time these threads held a set screw which made the boost gauge respond more slowly. It has since been removed. See the link to the MTech Tech Article under the following picture for instructions on how to remove the screw and why you would want to remove the screw.
threaded nipple
http://www.merkurtech.com/merkurtech/te ... tem001.php
Back on topic... the circuit board pops free from the tabs and you can solder the connections on the board
circuit board
During reassembly, I found it easier to stick the foam trim into the front section of the gauge cluster first and then install the gauge cluster behind it. This saved frustration and made the installation go very well.
foam trim installed
Like any repair project, I broke something else in the process. Both of the top screw holes in the gauge cluster surround broke out during reassembly. DOH!
"extra" gauge cluster trim screws
I completed the entire task in about 90 minutes.
edit: typos corrected and clarification added where necessary
edit: also just discovered this link when someone else woke the thread up
http://forum.merkurclub.com/forum/viewtopic.php?t=10560
