The Official Wheel Spec & Picture Thread
Let's try to keep this thread fairly regimented with no more than three pics to each post - one of the car and another, a close-up of the wheel. Plus, include as much detail about the wheel as possible. If a factory wheel, indicate OEM application and model years. Here goes....
Rota Slipstream 16x7 40mm Offset Steel Gray
Wheel weight 13.5 lbs
Clears coil-over lowered suspension without spacer utilizing 205/50 Kumho tires. Rear wheels are effectively spaced out 5mm however, due to use of thicker-hat Contour rotors (vs TC). Note, this almost eliminates the hub-centricity.
EVIL_XR4
Post by EVIL_XR4 »
I'm looking at getting some wheels for mine, i'm leaning towards 16s because i don't wanna deal with rubbing issues and rubber band tires. The problem is that i'm having a hard time actually finding 16s in the styles that i like. There's a wheel shop locally that sells just about any kind of wheel you can think of but damn near everything wheel skips 16'' in size (15/17/18/etc).
Is it really a big deal to run 17s? What kind of offset should i look into for a 17? If 16s will get me wider rims then i'd rather go that route, plus i don't want such a low profile side wall so if they have to be ultra low profile then i'd rather go 16 for that reason as well.
What i REALLY want are some CCW Classics:
http://www.ccwheel.com/files/wheelprofi ... id=classic
The only problem is that i have a mental block on spending 3k on rims :roll:
Anyone know of a hookup on this style of rim that won't cost an arm and a leg?
A couple kinds here. I dont have good pics of all the wheels i've had on this car so i'll go with the pics i have.
First we have 15x5.5 focus ztw wagon wheels, ET 52.5mm
mustang pony wheels, 16x7, ET 22mm
xr4man
Post by xr4man »
american racing spider series
'88 t-coupe
15x6
front 205-55/15
rear 215-50/15
offset - 25mm
rear 10mm spacer
sorry don't have a close up of these
'87 saab 9000 turbo
15x5.5
195-60/15
35mm offset
ian the re-animator
Post by Mike McCreight »
I'm on the hunt for a nice set of 16s too, just to round things out, and for better fit with the Cosworth arches and bumper. Here's a few other wheels I have...
These are Mullins (CSA) 17x7.5 with BFG G-Force 205-50-17. I dunno who measures tires for BFG, but I suspect a little creative license was used. They're MUCH larger than any other 205-50 I've seen. Took a little massaging to get them in there. I'm going with 235-40 and 215-40 on these next time. I think they're 35mm offset. My new 300mm brake setup (available soon!) fits under these, not sure about a 16" rim.
These are 17x7 Eagle Alloys. I think they're 40mm, with 215-45s Fit perfectly, too bad they're so blingy. Can't stand the chrome. Looks OK on a black car though. I got them with a car that needed a little love...
I really like these 15s. These are Wolfrace Thrust, NLA, but there's a great copy available from www.batinc.net 15x7 THese have Dunlop 8000s on them, another creatively sized tire at 205 55 15. They make the wife's Michelins in the same size look like temporary spares. The stack of 4 was 6 inches taller by comparison. The Wolfrace 15s clear the big brakes just fine, and are REALLY light.
mtnXRti
Post by mtnXRti »
Sorry no close up's. Running Compomotive MO1770's 17x7 with an ET of 35. Tires are Kumho 711's 205/40/17. I have stock springs but will put my BAT 1" drops on soon. I did have a slight rubbing issue when I would hit dips in the road at speed. front pass side I had to trim some plastic and bend the fender lip a little. Next time I will see if I can stuff a much fatter tire in the rear. seems to be plenty of room for them, thinking a 235 maybe 255
:roll: :roll:
More can be seen via the links below
'87 XR Street Ninja
'89 XJ Urban Krawler
Aaron
Longmont, CO
ShaggyZ
Post by ShaggyZ »
TSW Revo 17x7, 40mm offset, ~24 lbs! - same wheels stupid Saleen used on their Focus. Clears strut by less than 5mm and the tires rub at full lock but not bad.
Wish they were 17x7.5 and 30mm or somewhere near there if they all had to be the same, or 17x7 35mm in front and 17x8 25-30mm in back. Looks like a spaceship. It would also have been nice if they weren't 24 pounds for the wheel alone :(
Tires are Kumho Ecsta 711 205/40/17.
Wish I'd tried 215/40 in front and maybe 225/40 in the rear. If I keep these wheels, I'll do that when it's time to change tires. Didn't have money at the time.
I love the design, but not the weight or the offset and they're not available wider.
Josh
'89 XR: T5, 3in -- sold (no more XR's for me)
'77 280Z project
'03 Suzuki SV650S 12.15@108
'99 Suzuki SV650 -- for sale
John Brennan wrote:
Ed Lijewski wrote:I'm curious what the total weight is of the original phone dial wheel/tire combo. Anyone know?
YMMV 8)
That's what you run, right? Pop one off and weigh it.
Brilliant!
P.S. Don't anyone get all offended if I sweep through this thread every now and then and clean it up.
worked_xr
Post by worked_xr »
Here are mine:
ALT AT180, 16x7 ET40 with 205/45 Yokohama AVID H4S (though I have run 215/45 Falken Azenis and they fit perfectly).
MerlinMerkur
Post by MerlinMerkur »
Kazera KZ-V Grey
16X7 ET45 4X108 (Made for Focus) 15.2lbs-ea
20mm spacer in front to clear stock perches, 16mm in back (though uneeded)
Falken Azenis 215/45s
**NLA BUT, These come in 17" but I dont think for X108, only X114 and X100 (Hondas) AND, ASA makes them for Kazera and they have ones that look just like them still in manuf. Check out Motegi M12/MR12 if you like these too, more money but same numbers.
Oh, Evil as for those rims you wanted to, TSW makes one called the Kyamlimai or something that looks very similiar, its made for Contour SVT so look that up on TireRack or better... They come in 16 and 17" too so you could have your cake and stagger it too 8) for about 600$.
http://www.tirerack.com/wheels/results. ... toModClar=
OR
http://www.tirerack.com/wheels/results. ... sort=Brand
~Travis
87.5 Mono XR- LA3, FMIC, Adj Cam, Gillis, CAI/Cone, +15% rates - Koni adj, Coss frnt/rr sways, rr brc., Ported manis, 3" DP w/dualz, PBRs, rear disks and enough gadjets and switches to make Batman jealous! And more comin! Speak up.
PDenbigh
Post by PDenbigh »
Kosei K1 16x7.5 30mm offset running 245/45/16's.
Peter Denbigh
http://www.85xr.com
Colin
Post by Colin »
Type: Motegi MR1
Offset: +42mm
Pattern: 4x100/4x108
Weight: 21 lbs, 10.8 oz
Pics:
Type: Stern Face II Inter Touring
Offset: +35mm
Pattern: 4x114.3/5x114.3
Weight: 23 lbs, 5.2 oz
Pics:
Type: Dodge Magnum/300C steelies
Offset: no idea
Pattern: 5x114.3
Pic:
:lol:
Instagram @colinrdoyle
File to fit, paint to match.
Post by DSPXR4ti »
Ok... lets try that again, here is the left front tire and wheel 18x9's with 245 45 18 tires, I'll get a side view later.
They are Jongbloed Racing wheels and they are the JRW 330 with a bolt patten.
Now I will say this, yes I over payed for them but the guys (Jondbloed RW) are a half hour away and they work very very hard, coming to my house 6 time with different offsets to get the wheels just right, price was 3000 big ones but wait for the side view, I just have to put the car back together.
Garret
Post by Garret »
Mustang ten holes 205/55/15s up front and 215/65/15s in the rear, no trimming required on either but I don't run the plastic arches
thrashperformance
Post by thrashperformance »
wheels: 99 intrepid 16in steels with 98 ranger centercap. tires: kumho ecsta asc 205 45 16. once the car is repainted white and the rims nice black i will be going for that squad car look. long way to go, but the t5 should be in today and the posi rear with solid bushing too.
Image[/img]
jake nawrocki
1 cor 9:24
"if its not broke, i can problably still fix it"-tim allen
