Anglin's Racer Build and History
chadbratt
Post by chadbratt »
Something along these lines? A combo of a "standard" XR sway bar and an adjustable tension rod like the one seen in the back of this photo?
Chad Bratt
85 white XR4Ti. T-5, LA3, lots of goodies.
www.chadbrattphotography.com
Post by anglin »
I few posts got lost, so it's time to catch up. Here's the link picture that vanished:
I have one last part to draw before the assembly can be completed, screen shots taken, an FTP upload completed and a post made to share the kickass goodness with you. In the meanwhile, this should hold you over:
That's proof that the McMaster order came in today along with a few raw materials. I'll be getting weld inserts and some raw material Friday, then we're just a few machining tasks away from a completed product.
Post by anglin »
I believe I have about three hours invested total in fitting this assembly together so that everything works right. It looks so cool when you move stuff around. Anyway, thanks for being patient. I've been talking about this project since the beginning of the year and showing very little.
Remember, the goal of this design was to come up with a set of components that solves a problem. As it stands, all previous compression strut suspensions mount the compression struts where the anti-roll bar (sway bar) normally goes. As a result, you either have to lose the ARB or you have to affix brackets forward of the front suspension - Group A style. This suspension design includes a bracket that mounts to the place where the stock ARB bolts and incorporates both the compression strut and the ARB mounts into one. The rod ends on the inner portion of the track control arm and at either end of the compression strut allow for camber and caster adjustment, respectively. But wait, there's more.
We have two stock-style front ARB options for tuning the front suspension balance - stock (26 mm) and Cosworth (28.5 mm). This design gives those options as well. In addition to being able to set the front ARB stiffness to either stock- or Cosworth-equivalent ARB stiffnesses, there are also 4 points of adjustment in between those values. That's a total of 6 choices of anti-roll bar "sizes." If I really wanted it, I could also get an anti-roll bar that had the same stiffness as the super-rare 32 mm front ARB like the one someone posted for sale recently that was priced deep into the 4-figure price range. If I really, really wanted it, I could have at my disposal a range of front ARB stiffnesses as low as equivalent to 24.5 mm or as high as 32 mm.
So, there you have it folks...
- front suspension with rod ends and spherical bearings instead of rubber or polyurethane bushings
- fully adjustable front suspension with
-- camber
-- caster
-- toe
-- AND an adjustable anti-roll bar setup that lets you go from stock to Cosworth stiffess with ease
No modification to the chassis is required. After I bolt it on for the test phase, I can remove it and put the stock suspension back on the car.
And now for the pictures...
Post by anglin »
Complete setup:
Close up of the detail of the left side components:
Front view:
Front 3/4 shot showing all the components:
chadbratt
Post by chadbratt »
You are god. If you were a woman I would marry you. Whats the price we would be looking at? And when would it be available?
:notworthy :cheers
Chad Bratt
Are these the never-released factory 910 parts? :twisted:
Post by whitelx »
screw in, adj. ball joint so we can change the roll center?
Post by anglin »
whitelx wrote:screw in, adj. ball joint so we can change the roll center?
Excellent idea, but. It would probably just be a better idea to include a stud that goes from the outer TCA spherical bearing to the spindle that has a length that moves the roll center to a new location. All of the components are at specific angles to maximize the range of motion. A roll center adjustment would eat into some of that carefully designed range of motion.
As far as price is concerned... let us get through testing first. There will likely be some small design changes that come out of testing. That link I put up a few posts back is an example of how stuff changes as the design develops. We had no intentions to make a design like that originally. We were going to use a simplier solution, but design requirements made the simple solution one that just didn't work.
Hopefully testing will show that the monetary investment in these components is worthwhile.
ALConfederate
Post by ALConfederate »
chadbratt wrote:What's the price we would be looking at?
Heck, man, for something like this, if you have to ask you can't afford it. :)
I'll be watching this with interest myself. I've still got a few issues to deal with on mine, but the first area I have targeted for improvement is my suspension. I want a Merkur that handles like it's on rails.
Dave M.
'89 XR4Ti "The Black Death"
('cause it's black and spends a lot of time dead...)
michaelb
Post by michaelb »
Estimated time of release?
Nice job.
-Mike
Roll cages= viagra for car
Garret
Post by Garret »
it looks like the sway bar part will be a lot closer to the ground that before.
Post by anglin »
Garret wrote:it looks like the sway bar part will be a lot closer to the ground that before.
Yeah. The stock ARB connected directly to the stock TCA. Now it connects below. The link is about 3 inches long. There's about 9 inches from the TCA to the ground. That leaves about 6 inches (give or take the decimals from each of these measurements) between the centerline of that ARB link to the ground. Since the end of the ARB moves up and down with the tire, it's not as though contact with the ground is going to be something that the owner has to get used to.
Testing should be done by the beginning of June. Once we have some performance data on the improvement over the stock configuration, we'll gauge interest then.
chadbratt
Post by chadbratt »
Your probably right! But at least I can start saving my money! Plus if the performance numbers add up, it will be a must have for my plans.
Chad Bratt
anglin wrote:Well, that hood is finally going onto the car. I had to build a set of carbon hinge brackets that are epoxied to the hood first. Okay, so I bought the raw carbon angle and then modified it to fit my application.
Any left-over angle you want to sell? If not, what's the source? I need to get my carbon hood done as well.
anglin wrote:Here's the hinge brackets after the epoxy has set. The amount of research in picking the right epoxy and prepping for bonding is gross.
Care to save me the research time? :D
anglin wrote:I still have to make a carbon hood prop rod support (and a carbon prop rod while I'm at it
I was thinking about using one of those mono shock props, as used on some Audis and Volvos (possibly others). I've noticed in the junkyard that they wear with age and don't hold the original hoods up any more - the most worn one would probably be ideal for a 5 lb carbon hood. :P I imagine the weight of these (whatever it is), would be unacceptable to "Dr. WeightIsTheEnemy". :twisted:
And yes, I'm fully aware that I'm replying to a 3 year-old post! :lol:
Post by anglin »
DPDISXR4Ti wrote:Any left-over angle you want to sell? If not, what's the source? I need to get my carbon hood done as well.
The source is out of business, unfortunately. It was a great supplier. I have about 3 feet of 2 inch by 2 inch angle, but I might have to horde it for future projects. How much do you need?
DPDISXR4Ti wrote:Care to save me the research time? :D
I think I have a 'tube' of the epoxy I used left. If not, I'll poke around my receipts. Just remove the outer layer of epoxy from the hood with some 240 grit and clean thoroughly.
