The Official Wheel Spec & Picture Thread
TommyT
Here's a pic I borrowed from Merkurscorpio's Carlisle album since I don't have any pics with the new rear tires.
Borbet Type A's-Fronts are 16x7.5 et 15 with a small spacer to clear the calipers. Front tires are 225/40/16. Rears are 16x9 et 20 with 245/35/16. Absolutely no clearance issues at all however my rear quarters and front arches were modded before I purchased the car.
Tommy
Tommy
Tommy
Howell, NJ USA
Howell, NJ USA
dirtyford
86XR4Ti5SPD
- Level 3
Rota RB in royal gunmetal: 16 x 7.5, 4x108, 40mm offset with 205/50R16 Falken ZE912s. Stock suspension with no apparent clearance issues. Did have to rework the 3" pipe at the left rear.
Ed, Nashville
98 SVT Cobra, 1-owner 33K-mile convertible bought 8/15
86 5-spd, Solid Roof, sold 9/15 with 62K miles
03 SVTF #1965 of 3985, sold 9/15 with 68K miles
http://www.86xr4ti5spd.homestead.com
xr4ti41028
wow those rotas look good on there i was thinking about getting those ones or the rota grinds http://www.wheeldude.com/catalog/produc ... ts_id=1198
blizboy
turboplz
- Level 6
I'll have to take some pics and post tomorrow. I have Focus SVT 17x7 5-spoke rims, 215/45/17 tires and 10mm hubcentric spacers all around. The tires fit perfectly out back but I did have to trim the spring perch up front. I trimmed it all the way to the coil and have a bit of clearance now. I'm going to be installing 225/45/17 tires tomorrow so I will see if they clear.
As of right now with kyb front struts and stock springs, I only get fender rub on severe dips in the road. Overall a great ride, though any grooves in the road the car wants steer into.
Jason
2014 Focus ST
2014 Focus ST
turboplz
- Level 6
Hmmm, I was just going off what I was told when I got them. I will have to get a pic I guess to determine, but if they're physically impossible, then I would have to assume they aren't hubcentric, lol.
I also ended up going with 215/45/17's again as the 7" wide rim just really couldn't handle 225's effectively. Went with the Hankook Ventus v12 EVO's. I've read tons of great reviews on these, so hopefully they will perform to those reviews!
Jason
2014 Focus ST
2014 Focus ST
grve66
DPDISXR4Ti wrote:Sorry, but I have to waive this...turboplz wrote:I have 10mm hubcentric spacers all around.![]()
A 10mm hub-centric spacer is physically impossible to fabricate for use with our stock hubs.
to make a 10mm thick spacer that is hub centric should be rather easy. plus you could even get them made with a outer lip to be wheel centric also
Go grab a hub, stick a rotor on it, and then see if you still believe that.LS2XR4 wrote:to make a 10mm thick spacer that is hub centric should be rather easy.
Not following you on this one. Please splain.LS2XR4 wrote: plus you could even get them made with a outer lip to be wheel centric also
I designed a few spacers at one of my previous jobs. A 1/2" hubcentric spacer was the shallowest I could go which still feeling that the hub would not break off. It was really thin in the transition from the hub bore to the spacer's hub. This was for a SN95 Mustang though, but a 4 lug version was also designed for the rear of Fox Mustangs.
You can make a 10mm spacer that is hubcentric to the car's hub, but there wouldn't be any room to make the spacer hubcentric to the wheel.
grve66
I had 8mm ones made already for my 45 offset wheel. do they protrude past the hub bore, Sure. but you still have 8mm of hubcentric already so the extra 2mm I dont think will cause any issuesDPDISXR4Ti wrote:Go grab a hub, stick a rotor on it, and then see if you still believe that.LS2XR4 wrote:to make a 10mm thick spacer that is hub centric should be rather easy.
here is a pic of the rear with the 8mm see shiny spacer
http://www.amazon.com/gp/product/images ... automotive
this is what I had made, similar to this but 8 mm thick and hub centric.
here is what i was talking about with the extra lip.
http://www.zeckhausen.com/Product_Descr ... pacers.htm
or call him
http://www.wheeladapter.com/wheel_spacers.php
I'd say that 8mm thick is right about on the ragged edge of how far I'd go with a flat spacer. If you go any thicker than that you loose meaningful contact with the hub-center, give or take a few mm depending on the depth of the chamfer of the hub-center on the wheel.LS2XR4 wrote:I had 8mm ones made already for my 45 offset wheel. do they protrude past the hub bore, Sure. but you still have 8mm of hubcentric already so the extra 2mm I dont think will cause any issues
BTW, we're mincing terms a bit which is causing confusion. When I refer to a "hub-centric spacer", I'm talking about a spacer which provides it's own hub-center as part of the spacer itself. Thus, the wheel is centered by the spacer which overlaps the original hub. The thinnest you can make these is about 13mm.
Note that on the rear, if you've converted to rear discs, you can do some minimal spacing by using one of the many different discs which can be used.
grve66
That would be called a hub centric ring. There is hub centric spacers, Hub and wheel centric spacers and lug centric .DPDISXR4Ti wrote:
[/url]
