Decided to change the appearance a little after a jetta bumper fell into my lap.
1" OD .120 wall DOM tubing, stand off on same material with some C channel, TIG welded to fit factory bumper mount location. Also did a quick piece of angle to mark out center mount for the bumper. Sounds quick, but was a lot of measuring, etc to get it right.
This was painted satin black after it was all said and done.
Test fitting before making brackets to attach factory 4 stud xr4ti bumper mounts to jetta bumper...
Couple boring hours later of test fitting / sanding / and we're ready for prime! The front grill had some chips so i decided to respray this as well, while i was at it.
And two coats of diamond white later...
Will buff out this weekend so long as the paint is hard enough, then do another fit, then mount the obligatory air dam.
Post by Esteban »
Hey Ray, where did you get Diamond White paint? i need to spray my hood, grill, and bumper. Is it one stage? No clearcoat?
You can bring the paint code to NAPA and get single stage made up :)
And installed, mostly. Still have to figure out a few small things, but not bad :)
4" airdam
MODEL-Turbo
Post by MODEL-Turbo »
I hope my car looks half as good as yours does when im done Ray!
Andy
1927 Model-T
1988 Merkur XR4TI (build in progress)
1989 Merkur XR4TI Daily
1979 MkV Lincolin showroom mint condition
1994 4.0 Danger Ranger FOR SALE 64000 miles 4x4[/color]
Post by Esteban »
Hit up the junkyard and pick up a lip. But i dont think they would drop as low as how you have it now.
Krumm
Post by Krumm »
the vr6 lip for the mk3 is bigger than the standard lip
So much to do, so little money :(
-Robbie
Post by anglin »
The stuff you do still amazes me. Keep up the good work!
Krumm
Post by Krumm »
Esteban wrote:Hit up the junkyard and pick up a lip. But i dont think they would drop as low as how you have it now.
Not that Ray would get one, but the exterior section has a lot of bumper lips
http://www.tmtuning.com/vw/
-Robbie
Garg, i kind of like a few of those bumpers on there! :cheers
Of course, if i got one, who in their right mind would want a color matched to a merkur color, modded to fit a merkur, jetta bumper?! :beats head
lucky87
Post by lucky87 »
I probably would. htough i have a black car, i could live with it, besides im thinking about adding some white accents once i get some engine issues worked out
michaelb
Post by michaelb »
I wouldn't mind it either. Cars looking good by the way.
Roll cages= viagra for car
Haven't been spending too much time on the car recently or at all this off season. Time is ticking away. First event in 4 weeks. :oops:
But, here are a couple of images. I am hoping to get the fuel pump swapped over tomorrow to the Walbro unit.
Then maybe next weekend do a little welding. Anyway.
VW lights in, and working. I am also going to write a how to for here, for how to bypass the hazard switch and maintain working signal lamps. Actually it would be super easy to put in a different switch to have working hazards as well...
Anyway. Working VW lights.
And... Warning: Glowing Parts May Be Hot
Walbro fuel pump is in. Thanks mc2racing yet again!
Took connector from rail pump, spliced into some 12ga wiring, put thru the grommet for the tank pump, wrapped in some 3m rubber protectant tape, some heat shrink, etc...
Walbro Pump installed on the factory piece. Haven't yet clamped it down. Wiring thru a grommet, was then sealed with "seal all" sealant and heat shrink.
Sealed and shrunk.
While the tank was out i resprayed the straps (which were in remarkable shape) and brushed out the tank, then sprayed that as well. Figured... what the hell, let's have some fun.
Sure, it took nearly as long as the pump install, but it was definitely fun :)
jetrinka
Post by jetrinka »
Looks really good!
88 5-speed, Red XR
86 5-speed, 4x2 Toyota Pickup 22R
75 F-250, 4x2 w/390
2010 Impreza (wifes car)
