NEW Merkur part of the week
SvoSierra
Re: NEW Merkur part of the week
Has there been a sudden dump of TC calipers on the market? Now Mike an I seem to have a glut of them.
XR and Scorpio blower motor rebuilding, LED upgrades, XR lock service
NEW Replacement Scorpio & XR4Ti driveshaft u-joints are back in stock! :
http://www.ebay.com/itm/201071442485
(used) Esslinger 2.3 Valve Cover up for grabs:
http://www.ebay.com/itm/201071495789
NEW fiberglass Cosworth Front Bumpers now available at www.merkurdepot.com -> COSWORTH Parts
espacef1fan
Looking like I'll be ordering a bumper soon
Adam Escott
Dothan, AL
89 XR with Outcast Body in red
Duratec build in progress(need cams and stand-alone)
89 Scorpio. Needs everything
Dothan, AL
nzwinrz
The bumper look nice, looks like the maker omitted the corner trim from the mold, makes for not having to track it down. How does the quality and thickness of the fiberglass compare to others that you've seen?
Glenn
Glenn
Better than the mcrally ones you usually see thats for sure!nzwinrz wrote:The bumper look nice, looks like the maker omitted the corner trim from the mold, makes for not having to track it down. How does the quality and thickness of the fiberglass compare to others that you've seen?
Glenn
espacef1fan
Anyone bought one of these yet?
Adam Escott
Dothan, AL
Dothan, AL
Cosworth Grille:
http://www.ebay.com/itm/191239641973
Chrome plated XR auto trans dipstick and tube:
http://www.ebay.com/itm/191239634526
$159 XR Rear Disc Brake Kits:
http://www.ebay.com/itm/191238250259
NEW XR4Ti Front Wheel Well Liners starting at $1.00 with no reserve:
http://www.ebay.com/itm/201132911859
NOS Scorpio Fender Liners:
http://www.ebay.com/itm/201138768691
MOCA Patch and Invitation:
http://www.ebay.com/itm/191268612288
Random Collection of Merkurabilia:
http://www.ebay.com/itm/201138771269
NOS 89 XR coolant bottle:
http://www.ebay.com/itm/191283979785
NOS 89 XR upper radiator hose:
http://www.ebay.com/itm/201149316630
NEW 14mm poly bushings for rear sway bar:
http://www.ebay.com/itm/201149329497
NOS Scorpio front fender liners / splash guards starting at $1.00:
(relisted as the winning bidder thought they were for XR)
http://www.ebay.com/itm/201149314813
NOS XR RR wheel well liner:
http://www.ebay.com/itm/201162363876
NOS XR LR wheel well liner:
http://www.ebay.com/itm/201162363239
NOS Scorpio RF wheel well liner:
http://www.ebay.com/itm/191303456069
NOS Scorpio LF wheel well liner:
http://www.ebay.com/itm/201157943069
NOS 1989 XR upper radiator hose:
http://www.ebay.com/itm/201157939317
NEW XR Master Cylinder w/ Reservoir LATE STYLE BRAKE UPGRADE FOR 85-86 CARS:
http://www.ebay.com/itm/191304793806
NEW XR/Scorpio/Cosworth Powerflex Yellow poly rear beam mount bushings:
http://www.ebay.com/itm/201158590299
NEW XR/Scorpio/Cosworth black poly rear beam mount bushings:
http://www.ebay.com/itm/191304846807
NOS XR Cruise tip turn signal stalk:
http://www.ebay.com/itm/201196438464
NEW T9 Manual transmission fluid for all factory 5 speed XRs and Scorpios:
http://www.ebay.com/itm/201189298923
NOS XR round style transmission mount:
http://www.ebay.com/itm/191343109709
XR 2.3 Alternator relocations kits are back in stock at www.merkurdepot.com as well!
NEW XR4Ti & Scorpio Black Poly Rear Beam Mount Bushings:
http://www.ebay.com/itm/201204000548
NEW Merkur XR4Ti Left Hand Driver Side Fog Light:
http://www.ebay.com/itm/191379550377
NEW Merkur XR4Ti & Scorpio Steering Rack Boots:
http://www.ebay.com/itm/191379556101
NOS NEW Merkur XR4Ti Pair of Front Bumper Support Braces:
http://www.ebay.com/itm/201197504580
NEW Merkur XR4Ti Ford Sierra Mk1 Pair of Crank Window Covers:
http://www.ebay.com/itm/191379657604
NOS NEW XR4Ti & Scorpio Hood Prop Rod Grommet:
http://www.ebay.com/itm/191379662616
NOS NEW XR4Ti & Scorpio Hood Prop Rod Retainer Clip:
http://www.ebay.com/itm/191379665579
NEW XR4Ti & Scorpio Door Panel Clips Fasteners:
http://www.ebay.com/itm/191379681019
NEW XR4Ti & Scorpio Rubber Hood Bumpers:
http://www.ebay.com/itm/191388844924
NEW XR4Ti & Scorpio Lug Nuts for Factory Wheels:
http://www.ebay.com/itm/201202482275
NEW XR4Ti & Scorpio Door Striker Plates:
http://www.ebay.com/itm/191389507125
NEW Steel XR4Ti Key Blanks:
http://www.ebay.com/itm/201202564811
NOS NEW Ford XR4Ti Padded Key Blanks:
http://www.ebay.com/itm/201202569684
NOS NEW Ford XR4Ti & Scorpio Lighted Torch Key Insert:
http://www.ebay.com/itm/191389598794
NEW XR4Ti A Pillar Weatherstrip Seal:
http://www.ebay.com/itm/191389608272
NOS NEW Ford XR4Ti & Scorpio Clutch Pawl Quadrant Kit:
http://www.ebay.com/itm/201202586190
NEW Scorpio LED License Plate Bulbs:
http://www.ebay.com/itm/191389621727
USED:
Used Rapido XR4Ti front wheel well liners starting at $0.01:
http://www.ebay.com/itm/201206146965
Used OEM Ford XR4Ti rear wheel well liners starting at $0.01:
http://www.ebay.com/itm/201206147797
Used XR4Ti Scorpio Nice Tan Brown Genuine Leather Patch:
http://www.ebay.com/itm/191379490541
Used XR4Ti Tan Leather Seat Headrest:
http://www.ebay.com/itm/191379479934
Used Scorpio Gauge Cluster:
http://www.ebay.com/itm/201197602809
Used XR4Ti, SVO Stock T3 Turbo Wastegate Actuator:
http://www.ebay.com/itm/191379641801
USED:
New NOS XR Hood Latch:
http://www.ebay.com/itm/NEW-NOS-Merkur- ... 1208943953
New NOS Scorpio Hood Release Lever:
http://www.ebay.com/itm/NEW-NOS-Merkur- ... 1208940842
New XR brake caliper anti rattle clips:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1404185657
New NOS XR rear drum brake adjusters:
http://www.ebay.com/itm/NEW-NOS-Merkur- ... 1212112790
New XR smoked tinted tail light:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1212121934
New 2.3 Turbo downpipe nuts:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1213635078
New 2.3 Turbo exhaust manifold bolt set:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1213638515
And a couple used XR parts up for grabs as well...
Overhead console and dome light:
http://www.ebay.com/itm/Merkur-XR4Ti-Fo ... 1219109401
Pop out side window seals:
http://www.ebay.com/itm/Merkur-XR4Ti-Fo ... 1219116532
Hatch seal:
http://www.ebay.com/itm/Merkur-XR4Ti-Fo ... 1219120959
Driver's door seal:
http://www.ebay.com/itm/Merkur-XR4Ti-Fo ... 1219122391
Hatch seal:
Driver's door seal:
NEW Merkur XR4Ti Dual Gauge Pod Pillar:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1232381787
NEW T9 Roller Bearing:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1230583017
NEW XR gauge pod for clock area:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1432304328
NEW Merkur XR4Ti Ford Sierra Cosworth Polished Under Hood Stainless Plates:
http://www.ebay.com/itm/NEW-Merkur-XR4T ... 1230549844
Ford Sierra Cosworth RS500 Merkur XR4Ti 1/18 Scale Metal Car Model:
http://www.ebay.com/itm/Ford-Sierra-Cos ... 1232225806
Ford Sierra Merkur XR4Ti Miniature Plastic Car Model:
http://www.ebay.com/itm/Rare-Ford-Sierr ... 1434773827
Merkur XR4Ti Jacket:
http://www.ebay.com/itm/RARE-Merkur-XR4 ... 1232220600
