NEW Merkur part of the week
XR4Ti cars and parts - Please state your asking price and item location. Preface wanted ads with "WTB" in the subject.
Re: NEW Merkur part of the week
NEW XR4Ti and Scorpio Driveshaft Center Support Bearing:
https://www.ebay.com/itm/194802404599
Remanufactured XR4Ti and Scorpio Front Left Brake Caliper:
https://www.ebay.com/itm/194776172718
Remanufactured XR4Ti and Scorpio Front Right Brake Caliper:
https://www.ebay.com/itm/194308664442
NEW NOS XR4Ti Blower Motor Resistor Module:
https://www.ebay.com/itm/194867285477
NEW "square" 1985 XR4Ti & 88-89 Scorpio Transmission Mount:
https://www.ebay.com/itm/203837201320
(used) XR4Ti Dash in Raven Black:
https://www.ebay.com/itm/194864167556
NOS Ford XR & Scorpio Rear Beam Mounts:
https://www.ebay.com/itm/194955459448
NOS Ford XR & Scorpio Power Locking Rear Hatch Latch:
https://www.ebay.com/itm/203897598714
NEW XR Cosworth 16mm Rear Sway Bar Bushings Poly (Street):
https://www.ebay.com/itm/203886038192
NEW XR Cosworth 16mm Rear Sway Bar Bushings Poly (Track):
https://www.ebay.com/itm/203886039882
NOS Ford XR Gray Leather Door Panel Insert:
https://www.ebay.com/itm/203899201512
(used) XR Gauge Pod for A Pillar:
https://www.ebay.com/itm/203899229332
Late 2.3 single piece oil pan gaskets are getting increasingly difficult to come by lately...
I've rummaged through inventory to provide a couple solutions:
Felpro single piece 2.3 pan gaskets are in stock, ready to order at www.merkurdepot.com --> 2.3T Ford Engine Parts.
If you don't want to click through the site here's the direct link: http://merkur.50megs.com/custom.html
If you only want to use the genuine Ford part, we have a couple of those too.
NEW NOS Genuine Ford 1986-1989 Oil Pan Gasket 2.3 Turbo :
https://www.ebay.com/itm/203911105094
More XR A Pillar Gauge Pods :
https://www.ebay.com/itm/203913224351
https://www.ebay.com/itm/203911061148
NEW NOS 85-88 XR Coolant Bottle Y Hose:
https://www.ebay.com/itm/203910133006
New (late) XR4Ti and (all) Scorpio kick panel lens plug and play LED upgrade:
https://www.ebay.com/itm/203929969603
NEW NOS Genuine Ford Sierra Cosworth / Merkur Scorpio Rear LH Wheel Bearing Kit:
https://www.ebay.com/itm/195070828394
NEW-ish XR4Ti Turn Signal Switch Stalk:
https://www.ebay.com/itm/203985793504
(used) XR / Scorpio T9 5spd shift knob:
https://www.ebay.com/itm/195105607737
NEW XR4Ti Rapido Lowering Kit (Coil Spring set):
https://www.ebay.com/itm/204010177344
(used) Racer Walsh Adjustable Cam Gear Ford 2.3 Turbo:
https://www.ebay.com/itm/195154816495
XR4Ti Aluminum Cosworth Radiators are back in stock:
http://merkur.50megs.com/photo2_2.html
NEW XR4Ti Front Control Arms are finally back in stock as well:
http://merkur.50megs.com/catalog_2.html
Additional polyurethane bushings for XR4Ti and Scorpio are now available.
14mm Rear Sway Bar Poly Bushings:
https://www.ebay.com/itm/204056588190
Rear Inner Trailing Arm Poly Bushings:
https://www.ebay.com/itm/195257881263
Rear Outer Trailing Arm Poly Bushings:
https://www.ebay.com/itm/195257884611
NEW ESSLINGER Valve Cover for SOHC Ford 2.3 Engines:
https://www.ebay.com/itm/195264463685
More bushings!
XR4Ti / Scorpio Poly Rear Inner Trailing Arm Bushings:
https://www.ebay.com/itm/204083506376
XR4Ti / Scorpio Poly Rear Outer Trailing Arm Bushings:
XR4Ti Poly Rear Spring Pads:
https://www.ebay.com/itm/195303674864
XR4Ti NOS Motorcraft Front Strut Mount Bushing & Nut Kit:
https://www.ebay.com/itm/204087525625
NEW XR4Ti & Scorpio Heater Cores:
https://www.ebay.com/itm/204115883968
NEW XR4Ti & Scorpio Rear Axle Beam Mount Bushings:
https://www.ebay.com/itm/204115876177
(used) XR4Ti Koni Red Adjustable Front Struts:
https://www.ebay.com/itm/204116340477
XR Control Arms are back in stock:
https://www.ebay.com/itm/195449668739
Or directly at www.merkurdepot.com
Early XR and all Scorpio SQUARE Transmission mounts:
https://www.ebay.com/itm/204150731039
NOS Ford 1985-1988 Merkur XR4Ti Upper Radiator Hose:
https://www.ebay.com/itm/195420157836
(used) 1985-1988 XR Coolant Expansion Tank:
https://www.ebay.com/itm/195422016160
(used) XR4Ti A Pillar Dual Gauge Pod:
https://www.ebay.com/itm/204151584793
NEW NOS Ford Motorcraft lower radiator hose for 1985-1988 XR4Ti:
https://www.ebay.com/itm/195537583993
NEW XR4Ti A Pillar Trim Dual Gauge Pods:
https://www.ebay.com/itm/204171048177
NEW NOS Ford Sierra Cosworth / Merkur Scorpio Front RH Wheel Bearing Kit:
https://www.ebay.com/itm/195532362022
NEW Merkur XR4Ti Stock 10mm Rear Sway Bar Bushings Black Poly:
https://www.ebay.com/itm/195530646392
New XR4Ti silicone lower radiator hoses, and coolant tank "Y" hoses are back in stock:
New XR4Ti & Scorpio Driveshaft Center Support Bearings are also back in stock:
https://www.ebay.com/itm/204208326361
NEW Merkur XR4Ti & Scorpio 5spd Clutch Pedal Quadrant and Pawl Kit:
https://www.ebay.com/itm/195623899756
Ford 2.3 Turbo XR4Ti 90° Rotated Upper Intake Manifold:
https://www.ebay.com/itm/204237999072
