Volvo head...on the car!
Tommy99
- Newbie
Colin
MerkXRTurbo
I'd still try to find a way to support the header/turbo off the motor mount.
Colin- Would you consider doing an under-car turbo mount? The big plus of those is that your exhaust plumbing at the head is just like a N/A motor - use the stock manifold! I really wish I had found some time to look more closely at Compton's Ranger with the rear-mounted turbo at Carlisle. Talking to Planakis, they pretty much threw it together in an evening on a shoe-string budget, and then worked out the bugs over the next couple weeks. The toughest part was the oil pump, but apparently they finally found one up to the task after the first 3 or 4 failed.
MerkXRTurbo
I hate idea of under the car mount. What happens when you go through a puddle and your 1400 degree turbo gets cold water on it?
ClayM
- Newbie
Is the volvo head a direct bolt on to the 2.3 block? And what kind of hp gains are there from the head alone? Does the DOHC flow alot better than the iron SOHC?
________
ROOR BONG PICTURES
________
ROOR BONG PICTURES
MerkXRTurbo
How was that stupid? Do you even know what it's going to do? I do. It will crack.AlexD wrote:That was stupidMerkXRTurbo wrote:I hate idea of under the car mount. What happens when you go through a puddle and your 1400 degree turbo gets cold water on it?
MerkXRTurbo
From what I'm told, even the stock Volvo head outflows the Esslinger head.ClayM wrote:Is the volvo head a direct bolt on to the 2.3 block? And what kind of hp gains are there from the head alone? Does the DOHC flow alot better than the iron SOHC?
MerkXRTurbo
If metal is hot, and you throw water on it then it WILL crack. You wash your engine while it's cold... at least most of us would.
Alex, do you even understand simple physics?
fastmaul
can I take a moment to laugh my arse off!?? FPMSL!!!!!
phew ok, thanks..
Gentlemen...as you were.
phew ok, thanks..
Erik AKA MerkurSport's Bill payer. www.Merkursport.com The virtual Garage. Bring your own nudie calendar. You can now find MerkurSport on Facebook! http://www.facebook.com/pages/MerkurSpo ... 5756984607
GeneticRehab
Well most metal will not crack when its hot and water gets on it. But cast iron(witch are turbo housings,exhaust manifold are made out of) will crack if its real hot and suddenly gets cold. The reason behind this is the expantion rate of cast iron. When its near glowing and you get it real cold fast, the hot area stays expanded while the cold section is contracting rapidly. Cast iron dose not like to stretch. Plus when you make cast iron real hot and you dump water on it, you also make it get case harden. Witch makes it more prone to crack when its real thin.
Cast iron is real durable. But it has limitations.
Jason Liss
1989 XR Still in pieces
1986 XR Sold!
1986 XR Sold!
Colin
Merkenstein
GeneticRehab
