Broken Scorpio Hood Release
MarkM
Post by MarkM »
Posted on behalf of the couple with the problem. If you have a suggestion for them post it here please. I will encourage them to join the forum so that they can participate in the discussion.
Thanks,
Mark
-----Original Message-----
Sent: Tuesday, September 13, 2005 4:19 PM
To: [email protected]
Subject: Scorpio hood release
Hi, We are the owners of an '89 Scorpio. The hood release has broken
loose, and we can't get the hood open. We tried the technique listed
on your website (part of a section on unlocking the car), however, we
can't get to the release using the directions. Do you or anyone in
the club have an idea of how to open the hood?
Our mechanic is ready to cut through the hood, and we are sure there
must be a better way.
Thanks,
jaredaseltzer
Post by jaredaseltzer »
Oh, we can't have any hood cutting going on.
Where is this Scorpio located? Maybe someone who has done this before will live close by and can help out. Just a thought...if not I hope this helps...
https://home.comcast.net/~jaredaseltzer/HoodRelease.htm
ok, Mark, can you get the image on the above web page to the couple so they have a representation of what they are feeling for? Then either one of them, their mechanic or an ambitious 15 year old kid with skinny arms can see something that will give them an idea of what needs to be done. Let them know that the easiest way to do it, that I have found, is to reach up between the engine block and the radiator fan with a 6-8" long flat head screwdriver. Once their arm is up far enough, position the screwdriver forward, 90 degrees from their arm and insert the screwdriver between two fan blades where shown in the image then move the indicated lever to the left, releasing the hood.
This is not a hard task except it is done predominantly blindly, but if they can find someone with skinny arms and a good judgement of unseen...it will be a snap.
Definitely assure them not to give up... because this way they must use a 50 cent bar of soap to clean up...however if the hood is cut, it will cost a lot more to clean everything up.
xr4tifan
Post by xr4tifan »
First, I'd determine if the cable is broken at a place under the dash. If it is, the fix is easy - just get a pair of pliers to pull the relase. If the break is between the firewall and the actual actual hood mechanism, go with Mark's recommendation.
Mine just broke a little while ago and I'm still using a pair of pliers to open it. :(
'88 Scorpio - K&N air filter, custom hood, 17" wheels, dual exhaust
My recommendation is to remove the fan shroud starting with the lower half, from below the car. Remove the two sheet metal bolts (No. 10 head) screws on the bottom of the lower half, then with a blade or similar tool, pry apart the two plastic locking joints on the sides. With the lower half removed, one can get to the two sheet metal bolts holding the upper half of the shroud on the radiator. That allows sufficient room for average size forearms to squeeze through past the fan and reach the area shown in the linked diagram and move the hood latch to open it. :wink:
YMMV 8)
MarkM
Post by MarkM »
I sent an email reply to them yesterday with a direct link to this thread and Paul West posted their email to the IMON mailing list, so I think the problem has been suitably publicized. I appreciate the responses here, and I hope they will stop by to read them. Even better would be if they joined the forum.
BTW, nice diagram Jared.
Oh, and they seem to be from somewhere in Pennsylvania.
Mark
jaredaseltzer
After taking a second look, I think untensing the belts would be a snap from below the vehicle with the alternator right there and that would open up some more room to get an arm up in there.
Pennsylvania, huh? I am a South Carolina resident myself, but I know we have quite a few people on the forum in the new England area...I am sure one of them has a Scorpio, has popped the hood like this b4, and would be able to help out. Or at the very least be able to drive a scorpio to where the other one is located so they have something to look at to better understand how to solve their problem.
Well, Mark if you can (or if the owners of the scorpio are viewing this thread) please give a more specific location for the forum browsers to know if they can help...I am sure if I lived closer I would drive there to save a hood from being cut up.
Tom Hock
Easy way to open the hood of a Scorpio
Post by Tom Hock »
About five years ago Rapido Group sent me a sketch of a simple wire form tool to open the hood of a Scorpio with a broken cable. They gave it a tool number T-001. Start with a 30" length of 3/16 " or 1/4 " steel rod. Make a 90 degree bend two inches from one end. Measure back another two inches and make another 90 degree bend to form a sort of a Z shape, but with 90 degree bends and not the sharper bends as formed by the letter Z. Measure up from the last bend 21 inches and make another 90 degree bend so the rod will lay flat (All the bends are in the same plane). This last bend will form a 5 inch handle you will turn to relesae the hood latch.
If you block up the front of the car about six inches on one side it will be easier to complete this task.
On the center bottom of the one inch wide fan shroud, at the rear of the radiator, drill two 3/8" holes about 3/4" apart and cut the plastic material out between the holes to make a 3/8" X 1" slot. Keep the drill bit away from the radiator and make sure there is nothing in that area for the drill bit to hit when it breaks through (I don't remember if there is anything close).
Now snake the tool probe end through this elongated slot with the probe end pointing to the passenger's side. the tool should pass straight up between the radiator and the plastic fan blades.
At the top, where the latch is, there are two rectangular openings separated by about a 1/2 "section. You will need a good flashlight or trouble light to see these openings from beneath the car. They face the engine side of the radiator. Now snake the probe end of the tool ( with the probe end facing the passenger side of the car) into the opening that is on the driver's side of center, and as close to center as possible. As you do this rotate the handle of the tool clockwise (looking up from the bottom). This will bring the probe end of the tool into contact with the hood release lever and will release the hood. You will be working somewhat blind so it may take several attempts. It worked on the first attempt for me.
Since Repido Group was good enough to provide this information you might consider buying your new cable from them.
Tom Hock
Original owner of 1988 Scorpio with over 170,000 miles
MarkM
Post by MarkM »
We're getting some really good info in this thread, thanks guys! I received another email from the couple with the stuck hood last night. I'll post it below for your perusal. I'm still trying to persuade them of the benefits of joining the forum.
Thanks so much for getting all the help your call for information
brought. We have yet to get the hood open, but we brought the car home
to try again. The mechanics today got a real laugh when I climbed
under the car to try. I found the hole but not the release. What I
did do was get dirtier than I have been in years. From the grease on
my face and arms you'd have thought I was Pigpen from the comics. Dave
had tried, but he felt his hands were too big. So I was drafted.
We are going to try to jack up the car to see if that makes a
difference.
Barb and Dave
Mark
bendutro
Post by bendutro »
I have the Rapido manual hood release lever with instructions, I'd be happy to send it for the price of shipping.
It helps to have seen another Scorpio with the hood up so one can see what it is that your hands/fingers are hunting for from below. If that's not possible, maybe someone could take and post a photo of the open slots above the radiator support where the hood linkage is. The diagram posted was a good one, but again, not everyone has enough experience udner the hood to identify what the outline represents. :wink:
YMMV 8)
jaredaseltzer
Okay, here are some actual scorpio engine bay pics. They are a little dark but they should work...Wait for all four pictures to download, the last one is the most helpful...
http://home.comcast.net/~jaredaseltzer/ ... asepix.htm
MarkM
Success!
Post by MarkM »
I received this email yesterday morning, but didn't have time to post it until now. Thanks to everyone who contributed to the thread, and particularly to Roger from Hummelstown.
We wanted to thank all the Merkur members that responded to our dilemma
regarding the hood on our 1989 Merkur that would not open. After many
tries that almost worked, we finally got help from a member from
Hummelstown. Roger kindly came over and opened it for us. We can now
fix it properly and get the transmission repaired. What a simple thing
to cause such problems.
We have been Merkur club members for several years, but this is really
the first time that we have needed assistance. It came from all over
the U.S.
Thanks again,
Dave and Barb
Mark
jaredaseltzer
Awesome...great to hear.
