Something along these lines? A combo of a "standard" XR sway bar and an adjustable tension rod like the one seen in the back of this photo?
Excellent idea, but. It would probably just be a better idea to include a stud that goes from the outer TCA spherical bearing to the spindle that has a length that moves the roll center to a new location. All of the components are at specific angles to maximize the range of motion. A roll center adjustment would eat into some of that carefully designed range of motion.whitelx wrote:screw in, adj. ball joint so we can change the roll center?
Heck, man, for something like this, if you have to ask you can't afford it.chadbratt wrote:What's the price we would be looking at?
Yeah. The stock ARB connected directly to the stock TCA. Now it connects below. The link is about 3 inches long. There's about 9 inches from the TCA to the ground. That leaves about 6 inches (give or take the decimals from each of these measurements) between the centerline of that ARB link to the ground. Since the end of the ARB moves up and down with the tire, it's not as though contact with the ground is going to be something that the owner has to get used to.Garret wrote:it looks like the sway bar part will be a lot closer to the ground that before.
Any left-over angle you want to sell? If not, what's the source? I need to get my carbon hood done as well.anglin wrote:Well, that hood is finally going onto the car. I had to build a set of carbon hinge brackets that are epoxied to the hood first. Okay, so I bought the raw carbon angle and then modified it to fit my application.
Care to save me the research time?anglin wrote:Here's the hinge brackets after the epoxy has set. The amount of research in picking the right epoxy and prepping for bonding is gross.
I was thinking about using one of those mono shock props, as used on some Audis and Volvos (possibly others). I've noticed in the junkyard that they wear with age and don't hold the original hoods up any more - the most worn one would probably be ideal for a 5 lb carbon hood.anglin wrote:I still have to make a carbon hood prop rod support (and a carbon prop rod while I'm at it
The source is out of business, unfortunately. It was a great supplier. I have about 3 feet of 2 inch by 2 inch angle, but I might have to horde it for future projects. How much do you need?DPDISXR4Ti wrote:Any left-over angle you want to sell? If not, what's the source? I need to get my carbon hood done as well.
I think I have a 'tube' of the epoxy I used left. If not, I'll poke around my receipts. Just remove the outer layer of epoxy from the hood with some 240 grit and clean thoroughly.DPDISXR4Ti wrote:Care to save me the research time?
