intercoolers--all info!!!
turbofan wrote:
Ed Lijewski wrote:
turbofan wrote: i would think low front mounting it would be better than top mounting it since center of gravity has more effect than polar inertia. so... why's the mazda6 have a sunroof? top mount is EASIER. that's the only reason they do it. wrx, same way. it's simple and easy, and different. so there.
The Mazda6 has a sunroof; the MazdaSpeed6 doesn't offer it as an option (neither is leather seating available on that bad boy). :P
YMMV 8)
where do you get that it's not an option? boy, MOST mazdaspeed 6's come with leather. it's standard on the Grand Touring model. a power sliding moonroof is optional on the grand touring model and not available on the sport. come on Ed! http://www.mazdausa.com/MusaWeb/display ... leCode=MS6
I got it from Car and Driver, the most recent edition which I read last weekend, which specifically cited those two lacks as negative points among many positive ones.
Maybe the website is written by advertising types hyping beyond what they can deliver?
YMMV 8)
turbofan
Post by turbofan »
hmm, the mazdaspeed6 at the local dealer was equipped with both, along with a $3500 "market adjustment"... :roll:
Ed (yep, another Ed....)
Well, rethinking it, the C&D article might have been on sedans with "go juice" at under $30K. I'm sure/SURE there was no mention of the Touring Model. The link you pointed to lists the Sport and the Touring editions. Or, maybe the Touring edition was recently introduced and not available when the article was planned. :wink:
YMMV 8)
turbofan
Post by turbofan »
the first time i read that article was over 3 months ago :wink: . it's been like that since the beginning!! the mazdaspeed6 was never supposed to be an evo or sti beater. it's a comfortable sports sedan with punch, that's it.
ALSO, FYI: i've still been updating the opening post on this thread. every time i get more info, i update it. so.... check it out!
You might have seen an article on it alone, but this month's new edition has a comparo. See the cover of it here: https://www.neodata.com/hfmus/cdri/
Usually the standalone brief reviews are first impressions based on limited driving time/miles with less evaluative comments, pro or con, than the comparos or the long-haul wrap up reports on vehicles they've had for a year or more. :wink:
YMMV 8)
turbofan wrote:ALSO, FYI: i've still been updating the opening post on this thread. every time i get more info, i update it. so.... check it out!
You're doing a great job on this.
But I wish you'd credit the photos you're using; it's just good practice and policy and costs nothing. :wink:
YMMV 8)
turbofan
Post by turbofan »
YMMV 8)
:shock: :shock: HOLY CRAP! yeah, no kidding! i had intended to do so, but forgot!
MerkXRTurbo
Post by MerkXRTurbo »
I've got the Starion IC in my XR right now. I'm pretty sure the supercoupe one I have laying in my garage is better. Starion aren't too bad, but they're not exactly all they're cracked up to be.
MerkXRTurbo wrote:I've got the Starion IC in my XR right now. I'm pretty sure the supercoupe one I have laying in my garage is better. Starion aren't too bad, but they're not exactly all they're cracked up to be.
Yep, totally agree. The SC IC is a good one, once you figure out how to deal with (or eliminate) the funky in/outlets.
I think it's the Honda crowd that has praised the Starion cooler to be "all that", probably because it fits easily and with it's 1.75" fittings, it's easy to plumb.
turbofan
Post by turbofan »
the sc ic doesn't seem like it has very good exterior flow through the core though...
turbofan wrote:the sc ic doesn't seem like it has very good exterior flow through the core though...
:? :? How you figure? :? :?
turbofan
Post by turbofan »
the bars are so fat, and there's only one bar width between each bar (follow?)... it just doesn't seem like exterior flow through the core is very good. with the fat bars and not a ton of space between them, it seems like air basically must be forced through rather than easily flowing. look at the supra cooler and the isuzu npr... they have thinner bars, so the air can get around them easier on the outside. check out gus mahon's site and look at his exterior flow testing... corky bell also mentions it in his book.
i gotta look up that other book that was mentioned....
Post by anglin »
turbofan wrote:the bars are so fat, and there's only one bar width between each bar (follow?)... it just doesn't seem like exterior flow through the core is very good. with the fat bars and not a ton of space between them, it seems like air basically must be forced through rather than easily flowing. look at the supra cooler and the isuzu npr... they have thinner bars, so the air can get around them easier on the outside.
The "bars" are fat because it is a bar and plate IC core. I believe the Supra and NPR are tube and fin. It's the "tubes" that are narrow and the bars that are fat. The bar and plate IC cores are generally considered superior to the tube and fin IC cores, based on their relative performance. Additionally, the bar and plate are more expensive to manufacture.
You'll notice that the Forge "RS500" IC is bar and plate.
And the Pace "RS500" is tube and fin (it's the one in the background):
www.mc2racing.com
turbofan
Post by turbofan »
sorry, yes, i'm aware of the terminology and assembly, my brain just failed me at that moment!
yes, i've heard that the bar and plate are better... but it just seems to me like the SC core just doesn't flow enough air through its exterior. the fins on the outside are so tightly packed that it would seem airflow is nearly stopped as it goes through.
Post by anglin »
turbofan wrote:it just seems to me like the SC core just doesn't flow enough air through its exterior. the fins on the outside are so tightly packed that it would seem airflow is nearly stopped as it goes through.
So, are you talking about the fin density between the bars? Not the actual ratio of bar width to space-between-the-bar width?
The fin density is directly related to heat transfer out of the IC. A greater fin density increases the surface area and greater surface area increases heat transfer. Of course, there will be a point of diminishing returns, where you aren't getting enough airflow through the core to remove the heat that the fins are capable of transferring. I don't know where that point is. However, since increasing fin density also increases cost of the core, I would suppose that the manufacturer of the IC didn't exceed this number.
Here's an SC IC from Ed Key's web page:
www.mc2racing.com
