XR4Ti Rebuild... Completed [EGR Operation Information]
atomic
- Level 1
asdfsdf
atomic
- Level 1
makes it easier by not needing a flange on an aftermarket downpipe.what does removing the EGR do for ya?
the function of an egr is good . ppl with a stock tune may appreciate the very small gain they get by removing it which results in a slightly leaner afr .
i wouldn't bother if i were u... it does the enviroment and your motor's longevity good.
The one thing stated above that I agree with is the simplicity of the exhaust system. Though I'm curious why exhaust would be taken from the downpipe rather than prior to the turbo. However, there is plenty of misinformation circulating about the function of EGR systems in general and the EGR system in the XR4Ti. Let's clarify.
EGR general function:
The EGR does NOT operate under circumstances where you are trying to make power, like WOT, for example. Therefore, even if it makes the air/fuel ratio leaner, slightly or otherwise, it will not make a bit of difference when your foot is on the floor. The EGR operates under cruising conditions.
The purpose of the EGR is not to lean out the air/fuel ratio. The purpose of it is (mostly) to reduce combustion temperatures by putting a mass of inert gasses in the combustion chamber. Even at 600° F (or whatever), it is cooler than the combustion temperatures, thereby reducing the overall temperature of the gasses leaving the cylinder.
Additionally, EGR gasses consume some of the space in the cylinder which reduces the engine's requirements for air and fuel. This means your engine consumes less gasoline while cruising.
EGR function in the Merkur XR4Ti:
By way of the emissions recall that put the vacuum delay valve in the vacuum line to the EGR valve, the EGR system on the XR4Ti may NEVER operate. It may simply sit on the engine and never function. If this theory is true:
- you'll never get reduced combustion temperatures from recirculated exhaust gasses
- you'll never have the supposed "slightly leaner" air/fuel ratio
- you'll never have the effectively reduced displacement from EGR operation while cruising
Ford reduced the operation (possibly to zero) of the EGR system with their recall. Is the EGR really that important? If the EGR system never operates, is it critical for the sake of engine longevity? Does it really help the environment? Does an EGR system on the car open up the possibility for vacuum leaks? Yada yada...
www.mc2racing.com
www.mc2racing.com
atomic
- Level 1
You're right. I had your statement backwards. The sentence previous to the one I took issue with said leaving EGR on is good. The sentence I took issue with implied taking EGR off is good. Doh.i never stated the EGR's function is to lean the afr . in fact when engaged, it's opposite .
However, if removing the EGR causes a slight lean condition, when would a slight gain be noticed? If the EGR is only programmed to operate when cruising, do you notice a gain during cruising? Are there really power gains to be had during cruising? The EGR never would operate under WOT conditions, so it won't be slightly leaner then, if the EGR is removed. Where is the slight gain?
The emissions recall modification Ford did prevents the EGR from functioning entirely or delays it by a huge amount of time. I've never seen it operate when the check valve is installed during the KOER test, which one time it should operate. The only thing it is left to do is cause vacuum leaks (and give you code 34).All the egr needs to engage is vacumn, and the diaphram will open and voila exhaust into intake.
www.mc2racing.com
www.mc2racing.com
atomic
- Level 1
*thumbs up*anglin wrote: You're right. I had your statement backwards. The sentence previous to the one I took issue with said leaving EGR on is good. The sentence I took issue with implied taking EGR off is good. Doh.
Thats a good question. Will the gain be noticeable? i doubt it ..anglin wrote: However, if removing the EGR causes a slight lean condition, when would a slight gain be noticed? If the EGR is only programmed to operate when cruising, do you notice a gain during cruising? Are there really power gains to be had during cruising? The EGR never would operate under WOT conditions, so it won't be slightly leaner then, if the EGR is removed. Where is the slight gain?
your tests prove the EGR seldomly ever opens. So do we assume the programming compensates for that? i hope so ..
Therefor: the very small gain you'd receive from disabling the egr on a stock ecu would only happen at cruise and it will only happen seldomly because of the delay .
so there is no real point to the egr on these cars then
EDIT: If you remove it. make sure u keep the solenoid (pcm monitors that) . AND ensure u plug the hole properly !! otherwise u'll be replacing a motor hehe
Zackly.atomic wrote:so there is no real point to the egr on these cars then
The EGR control solenoid is not monitored by the PCM (ECA, whatever). There's no feedback on the EGR control solenoid or the EGR valve itself. You do not have to leave the solenoid connected. You can remove the solenoid from the car and leave the plug hanging, if you want to.EDIT: If you remove it. make sure u keep the solenoid (pcm monitors that) .
www.mc2racing.com
www.mc2racing.com
I specifically recall Rick Byrnes mentioning that they didn't NEED to include EGR to pass the then-current EPA emissions output guidelines, but they left it on any way since it was already done and left a greater margin of error that the cars would pass. Bear in mind, the emissions test that a manufacturer needs to pass is WAY stricter than the typcial end-user sniff test. The two shouldn't even begin to be compared.
I hadn't heard it suggested that the recall essentially disabled the EGR entirely, but it sounds like you have some data to back that statement up Chris. I deleted EGR from my car years ago (in every conceivable way), and have no means (or intent) of returning it without buying a bunch of new parts.
atomic
- Level 1
OH! well that is good news then!anglin wrote: The EGR control solenoid is not monitored by the PCM (ECA, whatever). There's no feedback on the EGR control solenoid or the EGR valve itself. You do not have to leave the solenoid connected. You can remove the solenoid from the car and leave the plug hanging, if you want to.
i thought the pcm monitored the resistance of the solenoid to see if it was there for emission purposes ..
that's good to know, it means less clutter in my engine bay now
Offtopic: How about the overboost buzzer ... can that be removed?
Nope, it's just an on/off switch. I'm pretty sure the Scorpio uses a PFE (Pressure Feedback EGR) sensor on its EGR valve though. Never owned a Scorpio, so I really have no clue.atomic wrote:i thought the pcm monitored the resistance of the solenoid to see if it was there for emission purposes ..
Yes. I think that sucker only has one wire. And don't forget about removing the buzzer too!Offtopic: How about the overboost buzzer ... can that be removed?
Brad, I'm going to eventually run a test on a car equipped with a vacuum delay valve. I'll discuss my plan here, just to be sure there are no holes in my method. I'll measure the vacuum at light, highway cruising load. I'll connect a vacuum hand pump to the delay (DeLay?) valve and duplicate cruising vacuum level. I'll time how long it takes the EGR to open. Tada!
www.mc2racing.com
www.mc2racing.com
Sure, although that's actually something I have not removed on my car. At the times it goes off, things are happening really fast all around you, so it's rare that you're actually looking at the boost gauge at that moment. An audible "gauge" is a nice feature under those conditions, to my way of thinking.atomic wrote:Offtopic: How about the overboost buzzer ... can that be removed?
atomic
- Level 1
Sounds like a reasonable approach. Hmmm, it occurs to me as we talk about EGR, we've been told that EGR is not engaged at idle. If correct, how is that accomplished? Forget about the Ken DeLay valveanglin wrote:Brad, I'm going to eventually run a test on a car equipped with a vacuum delay valve. I'll discuss my plan here, just to be sure there are no holes in my method. I'll measure the vacuum at light, highway cruising load. I'll connect a vacuum hand pump to the delay (DeLay?) valve and duplicate cruising vacuum level. I'll time how long it takes the EGR to open. Tada!
