Decided to relocate my alternator to where the AC compressor used to be. Mike's out of stock on the kits, but i have a series of spacers and stuff to try and make my own. I figured, if i couldn't do it, i'd order mikes. Total time invested in the bracket and finding the right spacers was about 2 hours. This makes mike's kit a steal as it's all ready to bolt in.
Took the stock AC compressor bracket, mocked up alternator, cut off bits that wouldn't fit, made spacers to position alt to where it needs to be and snug up. To appease Anglin, i drilled 3/8" holes btwn the ribs in the bracket (a total of 9, saving probably 0.1 oz of weight) to reduce weight.
Went out and picked up a turnbuckle style rod end thingie. Used rubber washers to allow slight out of alignment, drilled and tapped bracket to hold retaining bolt. New belt (old belt has like 40 miles on it, ugh, but this requires a new length.)
Had to then reposition upper radiator hose to allow fitment, then take turbo to FMIC tubing, cut the turbo outlet, reangle, and make a new turbo outlet to FMIC tube. next up is grind out the welds, look for any holes, reweld, then prep for paint. Then rewire to new alternator location.
New intake manifold will have the throttle body where the alternator was. Was a little more involved with this relo than i thought, but still, rather pleased with fitment. The fitment for the charge tubing is TIGHT since i'm using a non - above - the -radiator intercooler so i have to come down the side and in front of the alt. Weeee.
FWIW the 6 rib length is 60.5", while the V belt length for the same relo is 60". Odd. Anyway. Couple cell phone pics. Will get more after the install is... installed...
Final mockup of alternator, prior to rubber washers:
New charge tubing, before bead rolling and seam welding:
