Just installed a PE EEC
rat_n_a_cage
That really woke it up! I was skeptical, but it really did make a difference. The biggest difference seems to be more torque in the low end, and a flatter torque curve overall.
Now all I have to do is fine tune my plug gaps, but I only have the patience to do that like once a day at most. 0.031 is still getting "blown out" above 4500 RPM/18 psi
Greenturbo
- Level 6
Re: Just installed a PE EEC
do you find the computer had better WOT paramiters?rat_n_a_cage wrote:That really woke it up! I was skeptical, but it really did make a difference. The biggest difference seems to be more torque in the low end, and a flatter torque curve overall.
MEMBER OF FAST COMPANY
*86 XR4TI*82 Mustang TT351*65 Mercury Comet*
rat_n_a_cage
Without having data printed out, or time slips I have to rely soley on seat-of-the-pants impressions; based on that, I'd have to say without a doubt, yes!Greenturbo wrote:do you find the computer had better WOT paramiters?
robyn
I'll jump in this thread as I just put a PE EEC in m y XR as well - no repinning necessary (as needs to be done with the LA3 EEC), just ground pin # 30 to the body. Grounding pin 30 will keep the EEC in "high octance" mode as the SVO's had a regular/premium switch running to #30. FWIW, IMHO, the installation of the big VAM and PE EEC made a really big difference - esp. down lowrobyn wrote:did you need to repin any thing
rat_n_a_cage
AnHonestCitizen
Greenturbo
- Level 6
see sigAnHonestCitizen wrote:Something that is almost as important as an intercooler would be a bigger fuel pump. If you have strong stock pumps you will be okay, but at almost twenty years old, there's a good chance the stockers won't be up to the task. A lot of people go with the Walbro high flow/high pressure unit.
Greenturbo
- Level 6
as soon as i get this powerstroke intercooler cut downJohn Brennan wrote:Yeah, Greenturbo, looks like you'll be updating some of those numbers, eh?
ill be doing the PE and a header, should be a hoot!
Whistler
- Newbie
Alex20
