DSP to SM build
Re: DSP to SM build
1/16" toe out, you say?
I'm running 1.8 deg neg static camber and more than that for toe out - which might explain my corner entry push. THANK YOU.
:cheers
Re: DSP to SM build
Post by DSPXR4ti »
Ray wrote:1/16" toe out, you say?
:cheers
Your running street tires right Ray? can you get anymore camber out of your plates.
Re: DSP to SM build
Post by Esteban »
Lookin good with the hood!
Re: DSP to SM build
Post by DSPXR4ti »
Well I've been having an idle problem, and off idle throttle reponse, because I'm running the bo-port 1.1 and the A237 did also, my engine was loping some and just like the sound it made, so I found out if you install a little vacuum ball between the vacuum tee and the Map sensor, smooth it right out, very happy.
Pic's later:
Re: DSP to SM build
Post by DSPXR4ti »
Esteban wrote:Lookin good with the hood!
I would like to thank you very much, alot of "nice hood" all weekend long.
Re: DSP to SM build
Post by Esteban »
Where did you find out a little vacuum ball was needed? Is this something Bo told you if you're running a standalone? Cause we don't have MAP sensors right?
The hood should get your compliments all day long!
Re: DSP to SM build
Post by hEaT »
Esteban wrote:Where did you find out a little vacuum ball was needed? Is this something Bo told you if you're running a standalone? Cause we don't have MAP sensors right?
I know different ECU, but also common with the MS guys. With a more aggressive cam, the vacuum bounces around and causes havoc in the fuel tables which are strictly based on MAP only. Smoothing out the input (similar to what OEM did with the screw in the boost gauge) helps the idle a lot.
Re: DSP to SM build
Yeah, my AFR at idle is actually kind of amusing. 13.4, 14.8, 17.6, 13.8... Never thought to do a vacuum ball, tho.
Re: DSP to SM build
Post by whitelx »
I used a .023" welding tip in the vacuum line to the MAP sensor. Signal seems much smoother when compared to the straight 7/32" line I was using.
Re: DSP to SM build
Post by DSPXR4ti »
Ray wrote:Yeah, my AFR at idle is actually kind of amusing. 13.4, 14.8, 17.6, 13.8... Never thought to do a vacuum ball, tho.
This is whats mines doing, it's all over the place and like I said the off throttle thing is bad, so this really helped. I need to kick my tuner guy in the nutts, only because he's a tuner guy and should have know that.
Re: DSP to SM build
Post by hEaT »
DSPXR4ti wrote:This is whats mines doing, it's all over the place and like I said the off throttle thing is bad, so this really helped. I need to kick my tuner guy in the nutts, only because he's a tuner guy and should have know that.
Does your ECU allow closed loop idle control? I took the time to get it working on mine and helped out the AFRs at idle from varying coolant temp and IATs. I do have a stock cam though and haven't messed with cam timing.
Re: DSP to SM build
Post by DSPXR4ti »
DSPXR4ti wrote:Well I've been having an idle problem, and off idle throttle reponse, because I'm running the bo-port 1.1 and the A237 did also, my engine was loping some and just like the sound it made, so I found out if you install a little vacuum ball between the vacuum tee and the Map sensor, smooth it right out, very happy.
Pic's later:
So here's the little vacuum tube I made, I'm thinking of making a new one with some baffles in it, just to make things alittle better.
Re: DSP to SM build
Post by DSPXR4ti »
Here are my parts for my new trans mount because the Chevy trans mount was a POS.
here's all the parts that need welding up
The 2nd pic are parts that are going on my narrow tunnel trans mount to fit the chevy tail housing, so I can mount my new trans mount up
this should lock down the transmission for the next event.
I take pic's of it when it's done.
Re: DSP to SM build
Post by Esteban »
Do you really need a tube that big? Cant you use something like the vacuum ball for the cruise control or air vents?
Re: DSP to SM build
Post by DSPXR4ti »
Esteban wrote:Do you really need a tube that big? Cant you use something like the vacuum ball for the cruise control or air vents?
If I had one thats what I would have use but with the move I think the wife accidently :wink: miss place some of my boxes, funny how that happens.
