Merkur Depot Radiator and Intercooler Install (Lots of pics)
SvoSierra
Re: Merkur Depot Radiator and Intercooler Install (Lots of p
Post by SvoSierra »
Heat rises, so it will heatsoak a little while sitting still but once your moving and have a Cossie grille that will be long dissipaited 8)
This new version we put a small air gap between the rad and IC - you could sneak some rubber in there or a phelonic plate as an additional barrier.
I'll also give Mike a shout-out that these are quality units. I have 3 of them. :) No such problem as heat-soak. Think about it guys, the only time you would have heatsoak is if the engine is shut off and the air in the intercooler is stagnant. When it's running, even parked, air rushing through the inside of the intercooler will never let is raise more than a degree or 2.
XR and Scorpio blower motor rebuilding, LED upgrades, XR lock service
Apsalus
Post by Apsalus »
merkurdriver wrote:This new version we put a small air gap between the rad and IC - you could sneak some rubber in there or a phelonic plate as an additional barrier.
Ah, I noticed that. I haven't committed to one of your rad/IC's yet, but I was thinking about what I could squeeze in there when I do.
86XR4Ti5SPD
Post by 86XR4Ti5SPD »
I sandwiched a rectangular section of foil insulator between my IC and the shorty rad. It has stayed in place nicely, and I assume it is beneficial.
Ed, Nashville
98 SVT Cobra, 1-owner 33K-mile convertible bought 8/15
86 5-spd, Solid Roof, sold 9/15 with 62K miles
03 SVTF #1965 of 3985, sold 9/15 with 68K miles
http://www.86xr4ti5spd.homestead.com
otis147
Post by otis147 »
Any pics of the final install?? Curious how you did the cold side of the intercooler to the intake without a 45° piece
Skibob6
Post by Skibob6 »
otis147 wrote:Any pics of the final install?? Curious how you did the cold side of the intercooler to the intake without a 45° piece
WE NEED AN UPDATE!!! I want to see the final results of this installation. I was interested in theese parts but i need a more complete write up of required parts and fitment before i commit to buying it
99 Subaru Legacy gt wagon
69 VW bug
88 Merkur Xr4ti
Meow
otis147
Post by otis147 »
Here's my final install. I got a boost leak somewhere I need to track down. I literally bought piece for piece what he bought in his first post, aside from the radiator fan, which I had one laying around from a past... project (that never got started).
https://www.dropbox.com/s/jwgaod4cdlg9e ... 191425.jpg
Skibob6
Post by Skibob6 »
Thanks otis. Still havent decided if i want this front mount...
69 VW bug
88 Merkur Xr4ti
Meow
itking
Post by itking »
Ya thanks for the pic, Otis. That's exactly what I want to do. I have my cossie shorty in & IC. but the IC not hooked up yet.
Ron
1989 Merkur XR4Ti - Magenta [My XR]
1988 Merkur XR4Ti - Bunny [Wife's XR]
1988 Merkur XR4Ti - Raven [Daughter's XR]
1985 Merkur XR4Ti - Wombat [Youngest Son's XR]
1997 Dodge Ram 1500 4x4 5.9L - Betsy
2002 Buick Century Custom - Daily Driver
1968 Dodge Charger 383
otis147
Post by otis147 »
Skibob6 wrote: Thanks otis. Still havent decided if i want this front mount...
Was the easiest install I've ever done for anything on this cursed car. I removed my AC condenser while I was there, but it can still be kept if you want to keep your AC. Hardest part was trying to use a jack and 2x4 to balance the radiator while I bolted it up there myself. I ended up having to use a spacer on the top side of the radiator flange where it bolts up; if I bolted it up right, my hood would not shut for some reason :?
DAReese
Post by DAReese »
The best part of this setup is being able to keep your A/C.
Or maybe it is because it is 1/10th the cost of Dave Planakis radiator/inter-cooler combo.
KhanTyranitar
Post by KhanTyranitar »
I am definitely going this route when I finally am able to continue working on my XR. Hopefully towards the end of this summer.
1987 Ford Thunderbird Turbocoupe
Fully rebuilt engine, ported head w/inserts, oversized valves, ranger cam, matched intake, 57 trim turbo, custom FMIC, Walbro fuel pump, Kirban FPR, #60 injectors, PIMP, Stinger exhaust, Tru-Performance cat, CAI w/Pro-Dry filter
1986 Merkur XR4Ti
Work in progress
otis147
Post by otis147 »
For some reason, I cannot edit my last post. But I moved some images around in my dropbox folder and that link no longer works. Here is the updated link, along with an imgur link for archival purposes.
https://www.dropbox.com/s/jzsgolgopmdvu ... 5.jpg?dl=0
http://imgur.com/ZzD8WVQ
Chris_12
Post by Chris_12 »
Any chance anyone still has the pictures? I cant see any.
'89 Merkur XR4Ti Racecar-The Beast
'88 Merkur XR4Ti-The Build (need to get back to working on)
'87 Merkur XR4Ti-The Beauty
Chris_12 wrote:Any chance anyone still has the pictures? I cant see any.
Yeah, I wish there was a place that could store the pictures other than links on a thread. There are or have been many photo references taken and then lost.
Mike has some pix on his site, which is where you're gonna go to to order it, anyway:
http://www.merkur.50megs.com/photo2_1.html
Also, an excellent source for stored pix is on Picture Pages at Merkur Tech:
http://www.merkurtech.com/merkurtech/pi ... s/main.php
Sort by "Intercoolers," and I believe Mike's is the first one featured (along with many others). Merkur Tech is an absolute gem, and, I believe, underutilized and -appreciated.
Enjoy.
