TC EEC
It will fit, but there is rewiring needed, as well as the addition of an Air Charge Temperature sensor (ACT) in the intake manifold, and an intercooler. But the automatic model will not give as aggressive performance as the 5-speed, if I recall correctly. I don't know the specifics, so if anyone does, please chime in.
Vasja
MerkXRTurbo
I got my LA3 (from a manual tranny 88 TC) for around $90 with shipping across the US. That's a pretty typical price.
Freejack
Its an LB3, I believe, and from what I've read, the maps are just as aggressive as the LA3, mainly has the addition of transmission control. There was a recent thread on turboford:
http://www.turboford.org/cgi-bin/ultima ... 2;t=038277
Jake
Jake
The one from the A4LD-equipped '87/8 TC would be a 8UA or LB3. If anything, they should be LESS expensive than a LA3. The ignition and fuel mapping are actually very close for any of these. You need one from an auto car if you're running the A4LD, but either will work fine if you're running a 5-speed.John Brennan wrote:He's not talking about the LA3, though; it's the Auto version. I forget the nomenclature, and I'm too rushed to look it up. Who knows the differences in tables, etc?
Merkenstein
I am glad I own a 88TC 5 speed. Sure will make it alot easier already having the LA3 (35k) and big VAM. I am using the lower intake from the TC. I believe that is where the ACT sensor is located, as long as all the other sensor/plugins are the same as the XR's.
My TC body is going to the junkyard(it's shot). I have already took out the rear end, which it's going into a 87 LX 5.0 project car of mine, the motor from my TC is already in setting in my 85 XR, gonna do the LA3/big VAM and T5 conversion in a few months.
I checked on a SVO EEC at my local AutoZone. They said $95 for the EEC with $65 core charge, maybe I could try to change in one of my PK's if they didn't run the parts #
Vasja
Vasja
Vasja
Vasja
Vasja
Re: TC EEC
what stuff?AlexD wrote:and also the auto can work, but you'd have to rig some stuff up to get 4th gear to workVasja wrote:Hi, will a .3 turbo Ford Thunderbird 1988 with automatic transmission fit on my 85 XR? this is wrote on this EEC E7ZF-12A650-B1D
85 XR4Ti in Estonia. one of the three ones
