Speedometer Cable Removal from Cluster?
Baldy_54
- Level 2
I have the clutster loose and I can just barely get my hand on the SC. How do I remove it? It turns but that is not taking it off. Thanks
Simply squeeze the end of the quick-connector between your thumb and pointer finger and pull it away from the cluster. Don't feel bad - everyone goes through this the first time unless they've got the later setup that fastens at the false firewall. I converted my car to that type - much nicer to work with.
Baldy_54
- Level 2
Guess I am getting old. I tried to squeeze that white plastic knob which just turns. It seems to only have one place that looks like a squeeze spot and the other side is like an open slot. Maybe I need to eat some more "Wheaties". Doesn't the XR make anything easy?
Besides how to cost us lots of money?
BeefFajitas
- Level 6
merk23literturbo
Here's all you need to do. Feel the white part for the ridges the stand up and push that part towards the cable. The cable will come out when you pull on the cluster.
There is a tab that rides in a track around the cluster end. You are pushing the tab out of that track.
Frag
John R. Rowlands
Speedometer cable
Baldy_54,
There's a retaining clip on the speedometer cable that is screwed into the inner fender. Just unscrew that and it will give you about 2-3 more inches to work with.
John
John
Re: Speedometer cable
Good advise. Just be prepared for the screw that fastens that clip to be seized in place. Going after it with a leverage (i.e. ratcheting bit holder), will usually do the trick, but I've had to drill a couple out over the years. I *think* it is a Pozidrive head (PZ1) rather than Phillips. Using the correct bit will make a world of difference.John R. Rowlands wrote:There's a retaining clip on the speedometer cable that is screwed into the inner fender. Just unscrew that and it will give you about 2-3 more inches to work with.
John R. Rowlands
Speedometer cable
DPDISXR4Ti,
Jeez Brad. Just pop it with a hammer once or twice and it'll come right out!
John
John
Baldy_54
- Level 2
Are you talking about a clip that goes thru the firewall? There is a cable that looks like the it is metal and comes up to a round support and thru the firewall.
The speedo works but the tack is very low. If I can't get it loose, I will just put it back together and chalk it up to experience unlearned. At my age, life is to short to spend a lot of time on this. PITA it sure is.
Thanks for all the help.
John R. Rowlands
Baldy_54
- Level 2
