88 Scorpio
Re: 88 Scorpio
Re the rubber hose, is there a longitudinal crack in its midsection?
Note: I ask all these questions as to my knowledge no one else has posted pics of the Scorpio pump unit on any Merkur forum or equivalent. Jeff Herson is fully familiar about them, but not the rest of us...until now.
Re: 88 Scorpio
The hose, where you see it swollen, if I were to say clamp one end and put air pressure in the other end, it would swell and then expand, opening up like fish gills? Hard to explain, probably harder to understand by my poor explanation. If the hose is reinforced with string in a X fashion, when you put pressure to it, it would open up between all the X's.Ed Lijewski wrote: ↑Mon Jan 13, 2025 5:45 pm Re the rubber hose, is there a longitudinal crack in its midsection?
Re: 88 Scorpio
Re the HVAC dash vent doors, remove the fascias (easy pry with a flat bladed screwdriver) to see if they are twisted or not:
It will be interesting to see if Dan's lower mileage Scorpio also shows this kind of weakness, or not.
Re: 88 Scorpio
The HVAC seems to be working, not sure on the fine details just yet, but vents are moving & stuff, so...???Ed Lijewski wrote: ↑Tue Jan 14, 2025 5:19 pm
Re: 88 Scorpio
my8950 wrote: ↑Wed Jan 15, 2025 9:50 amThe HVAC seems to be working, not sure on the fine details just yet, but vents are moving & stuff, so...???Ed Lijewski wrote: ↑Tue Jan 14, 2025 5:19 pm
E
The issue shown in the photo is if the internal doors (just inside of the adjustable vents), close tightly (when HVAC so commands), stay in perfect horizontal open (ditto), e.g. The doors often are twisted from motor torque/weakened plastic in opening/closing fully.
You can tell nothing about this from hearing the motors whirl and the doors make some sounds.
Gotta look at them.
Re: 88 Scorpio
I'll check it out and follow up.Ed Lijewski wrote: ↑Wed Jan 15, 2025 2:12 pmmy8950 wrote: ↑Wed Jan 15, 2025 9:50 amThe HVAC seems to be working, not sure on the fine details just yet, but vents are moving & stuff, so...???Ed Lijewski wrote: ↑Tue Jan 14, 2025 5:19 pm
E
Gotta look at them.
Meanwhile, here's something to look at.
Re: 88 Scorpio
Missing part of Dead Sea Scrolls...
Re: 88 Scorpio
nah, just a build sheet, equal miracle though.
Re: 88 Scorpio
Where was that German build sheet found at? In the glove box?
Re: 88 Scorpio
What? Put your glasses on man!
Re: 88 Scorpio
Recent pics from installing a new pump in an XR (~140K) of the original filter and pump, and the filter after U thoroughly cleaned it.
I believe when new the filter material was either a color similar to as shown cleaned or possibly another color than changes into that when submerged in gasoline over time.
I thoughly/Thoroughly cleaned that filter. There were some black deposits inside in a few areas (the filter did its job).
The OE filter material is quite strong/resistant to tearing.
(I'm posting pics, from my phone, separately from my phone so they don't get mixed up or duplicated as in the past).
Re: 88 Scorpio
Re: 88 Scorpio
Re: 88 Scorpio
Re: 88 Scorpio
